cc-01 bearings?
I just recently purchased a tamiya cc-01 jeep wrangler and was wondering if anybody had any suggestions on bearings. I really don't want to spend almost $100 on acer racing bearings. Any other suggestions would be greatly appreciated. I would like to have a pretty good bearing, but really don't feel like spending a whole lot of money. This jeep is going to be a scale crawler if that helps at all. Thanks in advance!
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWXY1&P=ML]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWXY1&P=ML[/link]
There is a section near the bottom for some duratrax ball bearings. If you don't want duratrax then atleast you know how many and what size.
i checked into the whole towerhobbies thing and they are wrong. i went through the instruction book and came up with totally different numbers.
LOL, isn't the first time tower made a mistake. How do you drive your CC01? I had duratrax "teflon" shielded bearings in my m03 and after I tried rally driving in loose dirt, the bearing were rather crunchy. I had to take apart and clean all of the bearings before they'd roll somewhat smoothly again. So if you are going to do a lot of high speed dirt driving, you should think about getting rubber shielded bearings (or at least metal shielded) in places that aren't inside a case.
well the way i am going to run my cc-01 is for rock cralwing purposes only so what ever i can throw at it. you know: water, mud, snow, the normal crap. i have been looking at protek bearings but they don't make every size i need. i would like to get all of the same bearing. i am going to keep doing some more searching. i have an email into boca bearing but they have not gotten back to me as of yet. but thanks for the heads up.
KS
get the metal or rubber shielded b's. cant tell u how many duratrax bearings ive been through, and if your hitting water just use the oem bushings up front. those are just fine for low speed wet/muddy conditions
