RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Can you charge Lipo under 1C
Old 10-05-2009 | 05:53 PM
Default Can you charge Lipo under 1C
I have a Team Orion 2S 3800mAh Lipo and that the back of the battery, it says DO NOT charge battery at less than 1C or more than 2C.
Does that mean I can not charge it at less than 3.8A.
my power supply sucks and i can only charge it at 3.0A
Old 10-05-2009 | 06:00 PM
My Feedback: (325)
Default RE: Can you charge Lipo under 1C
You'd probably have to find out what the author meant. I think it is just fine to charge them as slow as one wants.
Old 10-05-2009 | 06:01 PM
rclugnut10's Avatar
i don't see why not, it may hurt you a little in the voltage category but not by much
the lug
Old 10-05-2009 | 06:04 PM
Brainanator's Avatar
I charge my lipos at slightly less than 1C, (0.9C) and you'll be charging at (~0.79C). I did my first few charges at like (0.8C). I've seen no ill effects after....5 cycles, lol
Old 10-05-2009 | 07:00 PM
midntpumkin's Avatar
i charge my 5000 25c at 1 amp sometimes, it just takes a long time to charge . i think it took almost an hour at 1 amp. i would call them and find out , maybe its because some chargers as default have a timed charge for lipos. one charger i use has a time out time at 120min just for safety .
call them, it couldnt hurt.
Old 10-05-2009 | 08:15 PM
rclugnut10's Avatar
yeah i'm limited to .5C with my charger and my lipo's are fine...
the lug
Old 10-06-2009 | 12:24 AM
redfisher1974's Avatar
ORIGINAL: midntpumkin
Would it not take 5 hours at 1 amp for your 5000mah pack? just saying.
Old 10-06-2009 | 10:56 AM
ORIGINAL: redfisher1974
if it were comletly dead yea , but i have my lipo cut off set high and it usually takes an hour. i also dont wait for the cutoff to tell me its dead too , i usually after 15 min running i ballance charge them back up. the 5000 i use are only for racing, also as the heats are IFMAR run so there not that long on the battery between heats
Old 10-06-2009 | 12:47 PM
I was thinking the same thing, it takes me about an hour or so at 4A on a 5000mah.
