RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
7 cell NIMH vs 8 cell.
Old 10-09-2009 | 02:53 PM
Default 7 cell NIMH vs 8 cell.
What type woud be better. Difference in handling, weight, etc. Btw i am soley a basher, no racing whatsoever. They will most likely from pro match. there ener-g 5000.
thaanks in advance
Old 10-09-2009 | 03:28 PM
Brainanator's Avatar
Default RE: 7 cell NIMH vs 8 cell.
Well I've heard amazing things about the new & cells, but they are too much for me right now. If your solely a basher then you might as well just go 8 cell, since it'll be faster and what not. Assuming your set up can handle the 8 cell...
Old 10-09-2009 | 03:48 PM
rebuilder's Avatar
Hitting the shift key produced a "&" when you meant a "7" im pretty sure.....................the eight cell will give you more speed, but there are not alot of stock ESC's made to handle an 8, an XL-5 can, you need to check the specs of your esc.
Old 10-09-2009 | 05:11 PM
I know the & mistake
anyway more info.....:
Difference in handling: not much, just the extra weight of the 1 cell + more power
weight: 1 NiMH cell difference
etc: might need a better charger, might need better ESC, might fry your motor faster (titan 12T is only rated at 7 cells), runs hotter
Old 10-09-2009 | 05:35 PM
yeah, i have a pede with the xl-5, and a s-600 motor. i wont be getting the batteries yet, just setting goals
I believe that a onyx 220 can handle a 8 cell.
EDIT: just noticed the title
Old 10-09-2009 | 07:54 PM
rebuilder's Avatar
Here's a motor you can run..................i've had a few of them, they're pretty decent and they are rated for 8 cells! This should "Speed the Pede"
Length: 2.26" (57.5mm) (can and endbell)
Diameter: 1.42" (36mm)
Shaft diameter: 1/8"
RPM: 25,300
Power: 144w
Operating Voltage: 4.8v - 9.6v
http://www3.towerhobbies.com/cgi-bin...?&I=LXLRE0&P=7
Old 10-09-2009 | 08:19 PM
i have some 7 cell hump packs from pro match i can sell you. if interested? they ate the 4200 ones with deans connectors
Old 10-09-2009 | 08:51 PM
thanks for the motor advice rebuilder, but i believe my current motor will speed it enough
thanks but no thanks josh.
Old 10-10-2009 | 08:02 AM
rebuilder's Avatar
Here's a good bargain..........this is cheap for promatch
http://promatchracing.com/proddetail.php?prod=42007H
