RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Heat and heatsinks
Old 10-12-2009 | 09:09 AM
Default Heat and heatsinks
Ok so, I have two Pedes one with a Co27, 19t/86t gearing stock wheel/tires. And a Method R 19 17t/90t stock wheels Masher 2k tires. Both motors run on the hot side and I was wondering if this heat sink would help out a good deal or just wind up looking cool on my motors? http://www3.towerhobbies.com/cgi-bin...LXTG83&P=0
Old 10-12-2009 | 11:00 AM
rebuilder's Avatar
Default RE: Heat and heatsinks
How hot are they running, have you measured the temps? Any form of cooling should help a bit.
Old 10-12-2009 | 11:20 AM
19/86 should be fine on a stock motor. All motors get kind of hot, but the question is how hot?
Old 10-12-2009 | 12:40 PM
For brushed motors you use the 5-second rule, if you can put your finger on the motor for 5 seconds, it's fine, if you pull your finger away in under 5 seconds, it's too hot.
And if it's too hot, don't bother trying to cool it, gearing down is the only way. With brushed running too hot is a symptom (of overgearing), so solve the root of the problem rather than trying to cover it up. You can add the heatsink afterwards to keep things a little cooler, but don't depend on the heatsink to make a hot motor run in a 'safe' range.
Old 10-12-2009 | 04:42 PM
5 seconds is a long time, i hold my finger on my brushless for 3 seconds and have to pull away, then i take a reading and its 160f
Old 10-12-2009 | 05:15 PM
That's b'cos for brushless the heat tolerance is much higher, you basically have to use a temperature sensor to tell (if you can touch the motor for even a second, it's okay).
Old 10-12-2009 | 05:31 PM
not been able to get an excat temp, I can hold my finger on there for 3 to 4 secs. Nothing to take the temp with, I just go by the "OWW HOT"" method =)~
Old 10-12-2009 | 05:47 PM
OvalRacer99's Avatar
As an electric motor heats up they lose power, so keeping it as cool as possible will help it to maintain peak power.
