RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Correct Allen Wrench for RR Metric 48P Pinion
Old 10-13-2009 | 01:42 PM
Default Correct Allen Wrench for RR Metric 48P Pinion
Hello All,
I purchased a metric 48P 17T pinion for my Tamiya DF-02 from Robinson Racing. I noticed immediately that the grub screw was standard. Since most everything I have IS tamiya and metric, I need to buy the right wrench. What is the "official" size so I can pick it up at my LHS.
Old 10-13-2009 | 02:46 PM
dirtpile's Avatar
Default RE: Correct Allen Wrench for RR Metric 48P Pinion
It's probably 1/16th but some of the smaller sizes are .050". If you have a 1.5mm see if it almost fits, if it's close you need a 1/16th if its way too big then get the .050".
Old 10-13-2009 | 02:51 PM
The standard Tamiya (1.5mm, I guess) is a tiny bit too small. The end result is that any kind of torque on the grub screw and it will slip. I essentially runied the grub screw by doing this. I will go get a 1/16th.
Darren
Old 10-13-2009 | 08:55 PM
rclugnut10's Avatar
RR's are 1/16
some others are 1.5 its most annoying a say we all just go metric
the lug
Old 10-13-2009 | 09:17 PM
I got a grub screw stuck in a rr pinion because of this crap.
