Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
Ignition cut off LED will turn off but engine continues to run
Old 03-03-2018, 02:01 PM
dingo9882
Default Ignition cut off LED will turn off but engine continues to run
I am pretty sure I have something incorrect in my setup with my ignition cut off. The problem is I am not sure where. My cut off led display with a green light and the light for the switch is on when the engine is running. But, when I hit the switch to cut the ignition, the light at the switch as well as at the receiver will turn off but the engine continues to run. I currently have a Futaba 9C transmitter. the Cut-off in hooked up to the 9th channel the receiver. Where in my setup did I go wrong....or is my transmitter setup incorrectly?
