Powersystem SportPlus and Futaba R6008HS
Hi Robert, planning to use the Powersystem SportPlus into a 80'span Twin Otter along with Futaba R6008HS 8ch reciever, and 10C transmitter. Though it's not that heavy plane neither has multiple servos per surface, I'd like to have rendundancy and good power distribution thru its 10 servos.
Questions are: 1) How do i get out 8 servos output thru the R6008hs; not very familiarized with this reciever. 2) Engines are glow, can i use the onboard Ignition Cutoff output to plug directly on/off Scale Lighting? 3) With the following sequence: lipo+swith hd +PSP lipo+swith hd can i charge both lipos thru its balance plug using 2 different chargers? Thanks, Etham. |
RE: Powersystem SportPlus and Futaba R6008HS
Hi Etham,
Please see below for answers. ORIGINAL: edagach Hi Robert, planning to use the Powersystem SportPlus into a 80'span Twin Otter along with Futaba R6008HS 8ch reciever, and 10C transmitter. Though it's not that heavy plane neither has multiple servos per surface, I'd like to have rendundancy and good power distribution thru its 10 servos. Questions are: 1) How do i get out 8 servos output thru the R6008hs; not very familiarized with this reciever. 2) Engines are glow, can i use the onboard Ignition Cutoff output to plug directly on/off Scale Lighting? 3) With the following sequence: lipo+swith hd +PSP lipo+swith hd can i charge both lipos thru its balance plug using 2 different chargers? Thanks, Etham. |
Thanks for the speedy answering.
Seems that the 8ch futaba reciever R6008hs has 1-7ch pins, and individual pin for battery and no 8th channel slot. Any thoughts? |
Hi,
Yes, the 8th channel and the battery port are shared. Even thought its also marked battery the 8th channel is primarily a channel. This is your 8th channel. |
