Equalizers II
When will the Equalizers be back in stock? I almost ordered a flight pack a few minutes ago but then noticed they weren't in stock..
RE: Equalizers II
Hi,
I am hoping about 10 days unit I get new stock. Working on this as fast as we can. |
RE: Equalizers II
That took you a whole 7 minutes to respond. That is just unacceptable. lol
What do you get a phone call when someone posts in here or something? Thanks for the super fast answer and I will check with you in a couple of weeks. Or should I just order the package and you send the Eq's when they are in? Thanks, Chris |
RE: Equalizers II
Hi Chris,
No, I don't get a phone call, I just work a lot trying to keep up with the business and developing new products. You can do it either way. If we can wait 10 days its a little easier to send the whole thing but I really don't care. I'm going home now. Got to eat sometime. |
RE: Equalizers II
Thanks Rob.
I for one appreciate the good customer service. Now, when I do order. I fly Airtronics. I know you don't make them for Airtronics for some reason, but Airtronics uses the same connector as JR. Do I order the JR one then? Thanks again, I appreciate the time and I will order from you as soon as I see them in stock. Chris |
RE: Equalizers II
Hi Chris,
Its a little trickier than that but not much. You should download the user manual for the PowerExpander first. Is this an end (side) loading receiver? The wires are too short to work with a top loading receiver. If so, then you need to see which side the power input is on and match that to the power lead on the JR or Futaba PowerExpander. They are on opposite sides of the board for the two. Please let me know if you have any more questions. Thanks, |
RE: Equalizers II
1 Attachment(s)
This is the AIrtronics reciever. I don't know what the others look like. It is end loading..
RE: Equalizers II
Hi Chris,
OK, you want to order the JR unit. This should work fine for you. I am not sure how the channel defaults are assigned, you may have to swap some to get aileron, elevator and rudder on the channels with 4 servo outputs which are buffered. The channels with 2 servo outputs are not buffered. |
| All times are GMT -8. The time now is 09:16 PM. |
