RCU Forums
-   Smart-Fly (Quest Engineering) Support Forum (https://www.rcuniverse.com/forum/smart-fly-quest-engineering-support-forum-328/)
-   -   PowerSystem Sport Plus Setup (https://www.rcuniverse.com/forum/smart-fly-quest-engineering-support-forum-328/9137072-powersystem-sport-plus-setup.html)
antksmit 09-30-2009 07:40 PM
Ok, I know that I'm likely asking a question that has been answered on this forum at some point - but I want to be sure I've ordered all the right hardware for my setup.
I've chosen to rig my 50cc Cap with a PowerSystem Sport Plus w/Ignition cutoff (ordered today). I am currently running 2 batteries - one for receiver/servos, the other for ignition. I have 2 charge ports on the plane, and 2 power switches. Obviously, I will run 3 batteries with the PowerSystem (adding the one for receiver redundancy). Will I be able to switch and charge both batteries attached to the PowerSystem using a SINGLE switch and charge port? This leaves a mechanical switch and a charge port for the ignition battery. Is this the recommended setup? Please let me know either way.
Anthony
rrritchey 10-01-2009 08:27 AM
RE: PowerSystem Sport Plus Setup
Hi Anthony,
If you use mechanical switches (like the JR Heavy-duty or Cermark Heavy-duty) you need one switch between each battery and the PowerSystem Sport Plus. If you use our failsafe switch (Pin & Flag or Slider) you only need 1 switch but you need two charge jacks, as both batteries are isolated from each other and must have their own charge jacks. Please let me know if you have more questions.
