Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
AquaCraft Motley Crew Off-Shore FE Catamaran
Speed - Electric For all your electric boating needs.
Old 02-20-2011, 07:32 PM
asupervee72
Default RE: AquaCraft Motley Crew Off-Shore FE Catamaran
Motley crew.
SPECIFICATIONS:
Hull Length: 29.5 in (750 mm)
Overall Length: 31.75 in (808 mm)
Beam: 10.4 in (264 mm)
Height: 6.5 in (165 mm)
Empty Weight: 65 oz (1843 g)
RTR Weight: 83 oz (2353 g)
Motor: AquaCraft water-cooled 6-pole 1800kV brushless motor (included)
Radio: Tacticâ„¢ TTX240 2.4GHz spread spectrum radio system (included)
Requires: (4) "AA" batteries, (2) 7.4V LiPo batteries of 4200mAh/20C or higher, compatible battery charger
MG
Specs
Length: 30 in (762mm)
Beam: 11 in (279mm)
Motor Size: A3630-1500Kv Water-Cooled Brushless
Radio: ProBoat 2-channel 2.4GHz Marine
Speed Control: 45-amp water-cooled programmable
Hull Material: Fiberglass Composite
Hull Type: Catamaran
Battery: 2-7.2V NiMH sub-C or 7.4 LiPo+20C (not included)
Kit/RTR: RTR
Drive System: Flexshaft/direct
so the aq cat is a little shorter and a little more narrow with a larger/ better power plant. So it will be faster and i doubt it will be a dog in the corners with the rudder set up like it is.
Old 02-13-2012, 08:43 AM
mavdriver
My Feedback: (14)
I just bought this boat the hull and the hardware only i install upgrade shaft from OSE , turnugy 120 esc , and aquacraft 2030 motor , x440 prop needless to say it runs very smooth and fast going try the grim racer 42x55 see what happens . very happy so far [8D]
Old 02-27-2012, 12:39 PM
tsherm31
tsherm31's Avatar
What batteries are you guys using for the Motley C? What can it handle up to?
Old 02-28-2012, 06:08 AM
mavdriver
My Feedback: (14)
Im running turnugys 2s 40 c 5000 mah , im waiting on the 65cs , get 4 mins fliat on the 40c s
Old 02-29-2012, 01:00 PM
tsherm31
tsherm31's Avatar
So I am looking to add a metal prop the octura x440. Should I go 2 or 3 blade? does it make a difference? thoughts? sorry I am a noob. From what I have read the 3 prop requires your boat to have more power and if that is the case can the MC handle it?
thanks,
Tyler
Old 05-10-2012, 05:57 AM
  #31
stuball56
stuball56's Avatar
This thread died a while ago. I wonder why though. I have an MC and after some hellava problems at first it is now the most fun I've hadin a long while. Mine is smooth as butter and carves the water like a razor. I just love this thing now that I have the bugs worked out.
I like this RTR thing, but I do wish you had the option to just buy the boat without TX/RX or just a hull with hardware. I would like to have a Proboat Impulse 31 too. But then I'll have three radios! one for Summit, one for MC and one for Impulse.
I don't know if the above poster is still active with his boat, but if so you probably know that the prop that is highly recommended is the X-455. I am going to try one today.
Old 05-10-2012, 05:59 AM
  #32
mavdriver
My Feedback: (14)
Go with 2 bladed prop
Old 05-10-2012, 08:07 AM
  #33
*delete M i k e u p delete*
go the 2 blade prop 440
Old 05-10-2012, 12:05 PM
  #34
asupervee72
ORIGINAL: stuball56
This thread died a while ago. I wonder why though. I have an MC and after some hellava problems at first it is now the most fun I've had in a long while. Mine is smooth as butter and carves the water like a razor. I just love this thing now that I have the bugs worked out.
x455 is not recommended at all with a 5636 size can at 1800 kv.
Old 05-10-2012, 05:00 PM
  #35
stuball56
stuball56's Avatar
ORIGINAL: asupervee72
ORIGINAL: stuball56
Whoops, you are certainly right. I meant to say 42-55 a Grim Racer metal prop. Sorry about that. Hope nobody took my advice, lol.
Old 05-11-2012, 08:01 PM
  #36
srt10
My Feedback: (20)
The M445 is the ideal prop I hear..
Old 05-12-2012, 11:26 PM
  #37
asupervee72
m445 rips hard on the 1800 aq motor.
Old 05-13-2012, 10:12 PM
  #38
srt10
My Feedback: (20)
I will try out the M447 when I get my MC this week..
Old 05-14-2012, 02:36 PM
  #39
flnsx
so whats the best for top speed? m445 vs 42-55 a Grim Racer
Old 05-15-2012, 09:50 AM
  #40
Diesel6401
m447 on spec? I don' know if the stock esc will handle it. With a CF42 the motor avg right around 60amps on 4s, grant it out of the box she runs a tad wet. Now with a seaking 120 and a m447 that might be rather interesting! I'll be waiting to see how this works out. I like when people push stock power
Agreed the m445 does rip stock, slap some 5.5mm on it though, the little 4mm don't like that prop lol. I love the grim 42x55. Doesn't have the top end of the m445 but better runtime.
ORIGINAL: srt10
Old 05-15-2012, 04:56 PM
  #41
srt10
My Feedback: (20)
YEAH BABY!
MC came today...
I think I will start with a X642 and see how this one runs
Old 05-15-2012, 06:29 PM
  #42
motorhead91
I went to the LHS today and picked up a MC. The box looked a little aged, I'm hoping it's not one of the first production runs with hull issues. I ordered the 42x55 Grim prop and some 30c 5000mah batts and see how it goes this weekend.
Old 05-15-2012, 06:42 PM
  #43
stuball56
stuball56's Avatar
After you run it successfully for the first time, tell me youre not blown away! I was, for sure.
Old 05-15-2012, 06:44 PM
  #44
motorhead91
That is the plan! I've been running a Rio ep every now and then for the past couple summers and decided I wanted something a little more serious.
Old 05-15-2012, 06:50 PM
  #45
stuball56
stuball56's Avatar
Oh, I thought it was your first fast boat. Oh well, you still might be blown away, it's a pretty awesome looking when flying across the surface of the water.
Old 05-15-2012, 07:02 PM
  #46
motorhead91
First fast electric. I switched from the nitro side, the constant tuning and fuel was a pain. I've still got my old MV...it moved pretty good on 50% and Grim 36x55
Old 05-15-2012, 07:55 PM
  #47
asupervee72
i was heating up with the 445, but my motor is aged and it was in a slightly larger Ms. Vegas duece so that is definitely a variable. Also it was a fairly warm day. a 447 is gonna need to be watched but i am very interested, Seems like it might be too much diameter and cause some instabilities.
I'm thinking about getting a x646/3 detounging, back cut and maybe reduce to like 44 mm. But then i'm not sure if 3 blades is where i want to be. I have a 645 i've been working on and it works real good with the 1500 proboat motor. Has anybody messed with the abc props, they have a couple that have me interested , but price is also a bit higher. Well this isn't a prop thread and i'm starting to talk about different motors and boats here so i'm done.
Old 05-15-2012, 08:27 PM
  #48
srt10
My Feedback: (20)
I'm curious about the 3 blades on this hull vs the 2's
Old 05-17-2012, 01:41 PM
  #49
Diesel6401
I ran a x447/3 cut down to 42mm detounged and tiped and the hull hated it. To much lift in the transom and caused a nasty bounce mixed with prop walk. Yanked it and stuck a 42x55 back on it and she was happy again. I may have gotten that prop to work with lots of tuning (maybe not), but didn't feel like screwing with it as I was crunched on time. Iwanna try a m445 with this motor I have and Iwanna try a prather 220.
Not running stock motor BTW.
Old 05-17-2012, 02:18 PM
  #50
srt10
My Feedback: (20)
is it possible this hull would like a X642?
extra pitch [:-]
