Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
Valvryn Proboat Horizon Not Working
Speed - Electric For all your electric boating needs.
Old 09-18-2020, 10:42 PM
  #101
ross100
Default Hey
The ESC unit with red light on seems to be whirring every 45 seconds for 3/4 seconds and then stops, is that normal?
Old 09-19-2020, 12:09 AM
  #102
Hydro Junkie
Hydro Junkie's Avatar
Nope, not normal. That is also one I don't know anything about so you may have to call the manufacturer for assistance since it sounds like an ESC problem.
Old 09-19-2020, 01:24 AM
  #103
ross100
Default Pps
The guy I bought the genesis from days sounds like the flex cable has snapped? Should I undo collet and take it out chief and have a look, does it sound plausible from your expert perspective? Thanks a mill.
Ross 😎👍
Old 09-19-2020, 01:33 AM
  #104
Hydro Junkie
If the cable has snapped, you should be able to pull out half of it without undoing the collet just by pulling on the prop. If the prop and cable won't come out, it can't be a snapped cable.
Old 09-19-2020, 02:29 AM
  #105
ross100
Default Cheesy peeps!
Yeah good point bud. This is wierd, just had the TFL warrior out and was flying and now exactly the same thing has happened with it?? Mmmmmmm
Old 09-19-2020, 03:01 AM
  #106
ross100
Default Me again
Iím thinking chief will take two boats on to guy at work on Monday, he knows what heís doing like you chief.
Old 09-19-2020, 03:02 AM
  #107
ross100
Default Private email
Do you have a private email that could communicate with you rather than through forum at times? Thanks a mill.
Ross 👍
Old 09-19-2020, 04:39 AM
  #108
ross100
Default Guy who bought genesis from reply
Think on the genesis you have to take the strut of the back and remove shaft completely you can then change for a race shaft but will have to cut to length. Look on Prestwich model boat for parts or eBay. When battery discharge esc cuts out to give you power to get back
Old 09-19-2020, 04:55 AM
  #109
ross100
Default Mmmmm
Defo not ESC cut off as rudder working on warrior and when apply throttle clunks as tries to move. Check a pic of the warrior bud, donít see a flex cable, everything seems housed at the back
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
