Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
My new props from ABC
Speed - Electric For all your electric boating needs.
Old 04-27-2023, 06:27 AM
  #476
Clugh
Banned
While my "brother" is amped up because he ran 50 in the 80s. Andy Brown, JA, and John Finch, are all current or former world champions and all have run well past 100 mph officially in rc boats.
Old 04-27-2023, 06:34 AM
  #477
Clugh
Banned
EXOs boat is nice and very fast but the district 12 direct here which includes my state is Don Ferrette who is a current and 25 time world champion. We used to be close but sht happens. None of it changes the fact that if Christian thinks he has something better he should visit d12 and bring his scale boats and cookie cutter rudders with him. Dons record is much more of a challenge in my mind. All set with NEUPOWER. Lukes got all the answers at 93.5% with his 41 series so he should come here and take it all.
Old 04-28-2023, 05:25 AM
  #478
Clugh
Banned
A beautiful same plane straight shot from the servo to the rudder on the RIGHT side. The 3mm rod gets sheathed with a 3mm id x 5mm od carbon fiber rod.
It touches nothing through the full range of motion. I actually had to dial the end points down to about 53% because at 100% it will induce too much turning which is always a good thing to detune from. The final product is as functional as it is beautiful with full threaded adjustment. The Hexfly HX-3225 25Kg/cm servo's torque on 6.6 LiFe volts has MORE than enuf holding torque. Its cheap strong and waterproof. Yes I saved where I could. UR FASTEST servos on the trim tabs as I have told you are over 540 dollars a pair, so yes the rudder servo get a discount!! I'll by a case of them for various rc and robotics projects. Its a strong servo. I'm more than satisfied with this setup.
Regards
Hubert
Old 04-28-2023, 05:35 AM
  #479
Clugh
Banned
Old 04-28-2023, 06:05 AM
  #480
Clugh
Banned
Default Powered Trim Tabs
So now were onto powered trim tabs versus a downforce wing added to the bow of an already built boat that should also be illegal. Ill also show you a UR servo as every one hasn't seen them. or wants to at 270.00 each! Even forum Futaba support hadn't hear of this till I showed them. They are fairly new and support FASTEST Futaba operation. The 10PX will support Fastest but the GYA-553 will not only SR and Fast. You will need a pair of GYD-550s if you want Fastest elevons.
Old 04-28-2023, 06:12 AM
  #481
Clugh
Banned
These wont fit the boat but are the general idea although my mechanics will be worked out somewhat differently with Futaba SR servos.
Old 04-28-2023, 06:15 AM
  #482
Clugh
Banned
I know someone is all up in my boat anonymously but they wont show the "straight Vee" version that they supposedly ran here. Dont know why they need that if the concavity met the rules....
Old 04-28-2023, 07:01 AM
  #483
Clugh
Banned
Currently Active Users Viewing This Thread: 8 (2 members and 6 guests)
Clugh*, BOHO1
Hi Powercroco from Scorpion motors I see you are in here under a perversion of my alias looking for improvement. Ill give you a way to cool and run the slow turners to appropriate boat propeller speeds without boosting the bad harmonics. Ill help you with all your iron loss soon enuf but not in here... This is about the boats...
Where's Luke with the battery consumption numbers? in the honeycomb hideout with Audiosmith?
Regards,
Hubert
Old 04-28-2023, 07:09 AM
  #484
Clugh
Banned
If you want to learn more about Talega based prop learning Jaguar and the 9N10P Crocodile Hunter you must come to the speeder power thread. Ill post something of value there later today. Right now I need to draw up a box for all the electronics and I think U will consolidate all cabling to a db25 parallel plug with a shield. This hopefully prevents spaghetti from running all over the inside of the boat.
In the meantime.....
Regards.
Hubert
Old 04-28-2023, 07:12 AM
  #485
Clugh
Banned
The "intellectually superior" German "Motor Guru" sleeps in my "Strange American" rooms...
Old 04-28-2023, 07:53 AM
  #486
Clugh
Banned
Ill help you with the unbalanced magnet pull or UMP!!! I see you struggling with the arm count +1 pole concepts there. If you insist on turning 20 poles over 20,000 rpm you should run the 18N24P ENERGYSTAR topology which gives you wider iron and a ultra clean signal at any rpm.
Old 04-28-2023, 08:00 AM
  #487
Clugh
Banned
See the real 1boho yall? This is me!! and this outrunner out of the washer is about 10 inches in diameter.
Im sure its enough for an ultralight!
Old 04-28-2023, 08:10 AM
  #488
Clugh
Banned
10 of these stacked at 120 volts could easily power a real Kneeler or Small drag V. Im thinking big....200mm x 200mm stator stack and 600 volt SiC based inverter. I have enuf room to build a real boat. I just need a few hands. James at ABC can prop it!
Old 04-28-2023, 08:27 AM
  #489
Clugh
Banned
IMPBA and NAMBA?
What about the APBA like my friend Lohring Miller!
This way we can bring the bigger sht out to play!!!
Old 04-28-2023, 08:29 AM
  #490
Clugh
Banned
Lohring has plenty of rc and real prop load data and assure me that the inertial most closely mimics an rc sailors prop load. He is NAMBA & APBA and I plan to work with him on tuning the prop learning inverter for a boat. But I also am conceptualizing a surface piercing dock or pool test rig. Andy has not committed to doing the props but Lohring works with Brian Buass.. If i can make a connection there thru Lohring or James it would be huge. Brian is smart as hell and preps awesome propsl... James at ABC recommends him as the preparer of the SAW props he sent me. I believe Brian is the man with electric props all day but still would like for Andy to commit to a few to have as well, but he may not be doing them at this time he hasn't told me yet. A few of my friends are in recovery from surgery and illness so I have to work around things a bit from my usual circles. Dyck Tyndall also told me he can't do me a fin right now he's still recovering. I'm not going to stress them out right now over anything so I'll just be real I don't have everything I really want because I want the products these guys make. I know what it does. That said if I cannot get Brian to prepare the propellers for me I will do them myself and age them based on James Scheafers instructions.
Old 04-28-2023, 09:00 AM
  #491
Clugh
Banned
So we get the basic idea of how it works. I plan to print the hinge tabs to insane's tab footprints. That way it works for everybody if they are into the so called for years "pie in the sky ideas" You have to remember I'm Im the "Active Canard" author on IW eons ago.
Im still "insane"
Regards
Hubert
Old 04-28-2023, 09:02 AM
  #492
Clugh
Banned
Active canard - YouTube
Old 04-28-2023, 09:03 AM
  #493
Clugh
Banned
Memsic 2125 - the heart of autonomy in active canards for rc race boats??? - YouTube
  #494
Clugh
Banned
It and the technology inside a GYA-553 is all old to me by 12 years it looks like LOL!.... since they told you it would not work or be fast enuf I figured I build it now that I have the time and resource gained from my professional ideas b4 it.
If it is working correctly it doesn't react to a blow over it prevents it from ever occurring.
This is a tribute to all the thread crashing Squirrels here and the eastside
TTYS
Hubert
Old 04-28-2023, 09:20 AM
  #495
Clugh
Banned
Understand the trim tabs are set up like a vtail glider and positionally governed by the attitude I table the boat with and save into the GYA-553 The entire time it is running the gyros job is to maintain the attitude and roll that was tabled. There is input from the stick if you want that but it is an autonomous thing that occurs in real time. I don't think it needs Fastest operation but I can accommodate that if need be. With two GYD-550's and UR servos.
Old 04-28-2023, 09:21 AM
  #496
Clugh
Banned
Hey Exo,
SEE MY "STARTER" KIT from Toys r us......
Old 04-28-2023, 09:23 AM
  #497
Clugh
Banned
See if they sell it there and how much of it is in your kids toy box versus boats made from shipping popcorn.....
Just ask Christian for the SKU #
Old 04-28-2023, 10:10 AM
  #498
Clugh
Banned
@exo
Dies wäre seine Antwort, als er mein Radiosystem im Vergleich zum netten Radio "Bruder" sah. Es ist lustig, weil es bedeutet, dass wir die gleiche Playbox haben, deshalb kann er sich nicht entscheiden, ob er mit mir spielen oder eifersüchtig auf mich sein will .
Hallo Hubert,
sorry aber die idee einen kreisel oder eine kreiselplattform vom kopter oder modellflugzeug zur stabilisierung des speedbootes zu verwenden ist uralt. Ich kenne ein Projekt, das Gyros verwendet. Ich habe sechs Kreisel aus dem ersten Heli-Einsatz und ab dem Jahr danach mit Heading Hold und 3-Achsen-Steuerung habe ich den Horizon ASX-Empfänger, der all diese Optionen enthält. Ich habe meinen Tunnelrumpf-Außenbordwinkel mit Kreiseln stabilisiert und habe ein Entfernungsmessgerät mit Laser und ein Horizontmessgerät, das immer darauf achtet, dass das Boot immer die richtige Position über dem Wasser hat.
Das ist also eine sehr alte Idee und wir sind nicht die ersten, die nach solchen Systemen suchen.
Ich schicke dir die Bilder von allen May Gyros, die ich später habe.
Gruß/Grüße
Christian Lukas
Natürlich hat das System, von dem er spricht, nicht die schnellste Geschwindigkeit oder Telemetrie, aber natürlich hatte er eine schnellere Version aus den 80er Jahren, aber keine Fotos davon auf einem funktionierenden Boot. Der einzige fertiggestellte Tunnelrumpf, den ich von ihm gesehen habe, ist die alte Schoßkatze mit Ralphs Motoren darauf, die er für Müll hält.
Wenn die Freundschaft an seinen unaufgeforderten Weltmeisterschimpfen und Unhöflichkeiten scheitert, dann tut er das. Alles, was er schimpft, bringt Sie auf etwa 50 Meilen pro Stunde. Es ist nicht fair, das ertragen zu müssen. Im Moment wird er dich oder Jörg so hochhalten, als wäre er es.
Old 04-28-2023, 10:13 AM
  #499
Clugh
Banned
@exo
Gesendet: Montag, 4. April 2022, 16:36:36 Uhr EDT
Betreff: Freunde werden, Neuanfang
Hallo Hubert,
wann verstehst du endlich, dass ich dich wirklich nicht dumm nennen will. Du warst mein Freund und ich habe eigentlich immer zu dir gestanden. Ich will dir keine Dummheiten vorwerfen. Wir hatten eine gute Zeit mit Jim bei den Schnellbooten. Los, reiß dich zusammen, ich auch. Wir brauchen keinen Okon-Idioten. Schauen Sie sich das Video des MHZ-Surfbretts an, es ist langweilig langsam. Das Laufrad von MHZ ist sehr schlecht, hat einen miesen Wirkungsgrad. Schauen Sie sich das Lampuga-Surfbrett mit Lehner-Außenläufer an. Es ist wahrscheinlich das schnellste Serien-Surfbrett, läuft 40 mph, jedes Kind kann sehen, wie viel besser es sich fährt. Vollgas für über eine Viertelstunde.
Lass uns wieder Freunde sein, das dumme Heruntermachen nützt uns nichts. Lass es dir durch den Kopf gehen.
Gruß Christian
Old 04-28-2023, 10:16 AM
  #500
Clugh
Banned
Aber jetzt im April 2023 sind meine Boote und mein Wissen "Toys R Us". Verstehst du, warum er das ist, was er für mich ist?
Er stellt dich mitten in seine Bewegungen. Es wird nicht gut enden, weil Karma eine Schlampe ist!
Ich war der beste Verbündete für ihn, fragen Sie Dr. Okon! und Michael
new speeder - RCU Forums (rcuniverse.com)
