My new props from ABC
#651
Banned
My breakdown of his power density is quite accurate to his own reports look again
Powercroco
Iron losses 280.9 watts
Copper losses.3 watts
Esc 7.2 watt
The battery loses 2.4 watts
His power density is 50.18 Km˛/g
His Kt is 4.81 mNm/amp
Km .1552 Nm/sqrt watts
Maxon eq 1.92 Max Eta 93%
NOTE MY LOSS CALCULATIION ON HIS ENGINE AND HIS OWN
can ray charles see the EXACT same 280.9 watts there????????????????????????????????????????????? ???????????????
Powercroco
Esc 7.2 watt
#652
Banned
so if anyone believes them you know nothing about math or electronics so report it i do not care. Every bit of it is based off REALTIE MEASURED Contants....while running on the speed control
it cant get any more real than that!
LOL!!!
LOL!!!
#654
Banned
And so Steve sent a full cowl as well so Ill actually build 2 boats from this kit . The 3 wing and this 2 wing with MLBoatworks laser cut kit that someone is already inquiring about if I will sell the boat. Gotta have the salt Snorkel!
#655
Banned
I plan to put 4 inch ralis in the CF shell with carbon fiber boon that run through the wings and certer section of the hulls to tie everything together.
BTW Steve Gualtieri will be releasing this scale fin soon
#657
Banned
As a build guide for the 3 wing I used Roger Newton Plans #159 and the recommended build Jig and wing placement templates from them. Ill likely build 2 so I can build both boats at the same time. The angle can be obtained from sheet 3 and the tunnel width from sheet 2.
#661
Banned
Did he create the first 3 bladed prop for U-1! Ort explain it to us? I also wonder did he have a 190 plus mph boat in the 60's like Jomes Sr.
#662
Banned
Kevin hired some other builder so if anyone else is interested in a 2 wing S or Q sport hydro LMK. I can deliver the boat ready to run and painted for 2000,00 plus shipping! They aren't cheap and its quite a bit of time an labor that goes into it for it to run true and handle well.
Regards,
Clugh
#665
Banned
If the 41 series Lehner or 4225 scorpion is worth a flip then their editors will drop them in the calculators and telll you the expected performance with an actual boat propeller!
FE CALC
Showds In a performance hydro with 10s lipo @ 9800 mah and a castle 240. Prop wizard selected an ABC 1918 as the most efficient prop for the setup. Resultant: 28,221 rpm 141 amps 4,955.78 watts Pin 4,728.58 watts Pout run time 4.15 minutes est speed 79.20 mph or 127.46 Km/h Eff. 95.42%
FE CALC
#666
Banned
02-15-2022, 03:44 PM #101 (permalink) CHX2
Registered Users
Hi Hubert,
thanks for offering all your know how . The 3d print stator are a real step vorward . i will speak about them with Albert from EOS. The have since so e years new micro 3d printer. They can laser sinter parts the sice of 5 micron.
I've talked to Albert a few times about sintering a few model components with the micro printer method, which instead of insulating material simply have micro gaps that are only kept at a distance with tiny spacer structures. This makes the components stable but insulated against eddy currents in the component itself. I need toroidal cores and a few rectangular components. A coil is wound on the toroidal core and the rectangular parts are exposed to alternating magnetic fields between two Helmholz coils and the heating is recorded over time. This can then be compared very well with all sorts of sheet metal components made from different materials.
You will certainly have a frequency generator to be able to carry out such measurements.
The copper wire bender has now rewound a 12 slot 4 pole motor and inserted the stator into the housing. The winding heads are now much too big and are also still very close to the housing components, which are made of aluminum. They are now properly heated by the alternating fields. Hacker motoren has been doing this for years . They copy the engines and tune them but don't understand that some rules of engine building are easy to follow. Anyone who builds such a beautiful engine heater does not exactly show know-how. It also makes more sense to use a motor that has been wound with multi-wire winding, for example, and therefore has fewer losses in partial-load operation. It can easily be selected with fewer turns because you can fly more energy-efficiently for the approaches or the ascent and then have more capacity in the batteries available and then at top speed flight can afford a higher performance.
We will see, when recalculating the maximum efficiency by no-load current by starting current square root of 1 - and everything squared gives the Lehner the highest efficiency compared to the Scorpion motors from Decker.
Happy Amps Christian2022, 03:44 PM15-2022, 03:44 PM
Registered Users
#668
Banned
The boys have a right to the truth and accuracy that matter to their pockets and models performance. The forum is nothing without them! the petition TO SEE THE INFOMATION has over 100000 signatures.
#669
Banned
See when you build scale boats you dont use manuals from Fabio Buzzi you use a Building Jig.
If you want reality all i have to do is a roll call for the members here that have them.....
The only "builders" that wont have them are building laser cut kits with eazy tabs or people who have never built one
Its a simple reality test. Just ask to see his building Jigs. I have several!! This would be the newest one.
They wont produce one for scale boats or a composite scale or scratch built hull of any kind!
Ad hominem on a forum is absolutely all that is...the proof is in the build!
#670
Banned
This was sent to me in email. Its is a Corvus proposition as far as I'm concerned and very illegal in our sanctioned bodies. If it were protested which it wasn't and straight edged that would have been shared with you versus the ad hominem.
#672
Banned
Currently Active Users Viewing This Thread: 2 (2 members and 0 guests)
Clugh, BOHO1
Hi Ralph I see you are hanging in there.. You may also be able to create a 3d map in MATLAB. There are some other pc apps like Maple etc. that may do this as well. Its worth it to know at various load point where you really are.
I have to say Im quite disappointed that the academically exempt can;t stand in a Rogerian room with me "the starter".
But anyway look here for props for your boat.
My motors still better than yours but you need some pitch on your large marine engine so look here:
Octura V900 propeller (torgg.com)
Clugh, BOHO1
#674
Banned
Id like to say something to any of the IMPBA body members here and Im not current on my dues.
Not trying to be funny but you guys not going to induct JA and AB into the IMPBA Hall of Fame???
