Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
Micro rigger (12 inches)
Speed - Electric For all your electric boating needs.
Old 07-27-2007, 03:55 PM
alloutcustom
Default Micro rigger (12 inches)
Hey im making a micro rigger for fun. doesnt have to haul, just cheap fun.
here is what im planing on using
[link=https://www.unitedhobbies.com/UNITEDHOBBIES/store/uh_viewItem.asp?idProduct=5379]Motor(micro outrunner)[/link]
[link=https://www.unitedhobbies.com/UNITEDHOBBIES/store/uh_viewItem.asp?idProduct=2054]LiPo Battery[/link]
[link=https://www.unitedhobbies.com/UNITEDHOBBIES/store/uh_viewItem.asp?idProduct=4317]Esc[/link]
Im making a .032 wire drive for it. im open to any suggestions...
BTW, the only reason im using an outrunner it because i cant find small enough props that will work with an inrunner, if you guys know where i can get really small props ill use an inrunner
here are some pics of it so far...
ID:	730949   Click image for larger version
Old 07-27-2007, 04:14 PM
alloutcustom
Default RE: Micro rigger (12 inches)
Oh and one question what is the best way to thin epoxy, Stovetop? microwave? dont know how much to heat it either, thanks,
mike
Old 07-27-2007, 05:37 PM
dicko
dicko's Avatar
if you want t heat epoxy, use a hair dryer. if you want to thin epoxy, use epoxy thinners. heat helps it set, it will make it runny for a brief period, thinners helps to get a nice smooth coat.
Old 07-27-2007, 06:40 PM
alloutcustom
what do u guys think? is it worth trying or no?
Old 07-27-2007, 06:53 PM
bebopin64
go for it. it can be fun and cheap
Old 07-28-2007, 08:46 AM
alloutcustom
i finished the hardware, it mainlt made of .032 brass so its a little heavy. it looks nice tho, just have to sharpen it now, ill post pics after i find my file, lol.
Old 07-28-2007, 09:55 AM
hellomynameisdookie
ORIGINAL: bebopin64
fun and cheap
HA! No such thing.
Old 07-28-2007, 10:17 AM
Ron Olson
Ron Olson's Avatar
To thin epoxy, use some denatured alcohol. You can put in on then wipe the excess off with paper towels. Yes, the paper towel trick works but do it right after you lay on the epoxy.
Try www.microhydros.com for more ideas if you already haven't. It's a great site for info on small boats.
Old 07-28-2007, 10:33 AM
My Name Is Brad
My Name Is Brad's Avatar
cool rigger. I hope it works. I dont think I will have a rigger running for a while just b/c I dont have the money for the hardware. Its all so damn expensive. If I do get money for hardware, I will remake my rigger out of all balsa, b/c mine is too heavy. I will probably also make it smaller kind of like yours. good luck
Old 07-28-2007, 01:17 PM
alloutcustom
thanks,i made my hardware from brass and soldered it. u could do that until you get enough money for good hardware, i have the money except theres no hardware thats small enough.
Old 07-28-2007, 02:06 PM
hellomynameisdookie
Even if you do have the money, you can still make your own and save probably $60. Plus, it's fun and rewarding.
OSE has the most reasonably priced micro hardware I've seen yet. http://www.offshoreelectrics.com/pro...mcr-mhd&cat=69 If you made your own you'd still probably save around $40.
Old 07-28-2007, 02:23 PM
alloutcustom
ill get a picture of it tonight, i have finished the left sponson, just working on the right one and assembling it.
Old 07-28-2007, 05:00 PM
alloutcustom
the hardware is crappy at this point, im still gonna file it a lot and make it strait and then sand it. its doesnt have its clear coat yet but here is what it will look like
ID:	731475   Click image for larger version
ID:	731476   Click image for larger version
Old 07-28-2007, 05:22 PM
alloutcustom
does any body know where to get the plastic octura props? i ve looked at a lot of places and they dont have them
Old 07-28-2007, 05:52 PM
bebopin64
ORIGINAL: hellomynameisdookie
ORIGINAL: bebopin64
fun and cheap
HA! No such thing.
your thinking of fast and cheap. you can have fun and cheap.
Old 07-28-2007, 08:05 PM
alloutcustom
i found some dumas props, 1" and 1 1/4". should i use them or are they crap?
Old 07-28-2007, 08:26 PM
spicedcrab
hi,
looks great, your really moving on the build it looks like. i built a few scratch riggers too and tried outrunner motors, they tend to get hot, i found a pretty good cure for my last rigger. when you make your motor mount use "L" angled alum (from like home depot or so) cut it the full width of the hull so you can epoxy it to the sides, have one side hold the motor and the other side go right through the bottom of the boat so that it is exposed to the water but epoxied flat out side of the hull. water will cool the exposed part and transfer heat from the base of the outrunner. you can see the exposed part in a couple of the pics that show the bottom of the hull.
to see the pics, look at post number 40 and 41 here http://www.rcuniverse.com/forum/m_60..._3/key_/tm.htm
building can be fun,
john
Old 07-28-2007, 08:36 PM
alloutcustom
cool idea thanks, ill do that because its goin to be running on a 3-cell lipo and will probably get hot.
Old 07-28-2007, 08:45 PM
spicedcrab
i just looked at your equipment list, im just guessing here, but i think the 10amp speed controller will not hold up very long in your boat. maybe find one in the 20 amp range, boats are hard on esc's. my suggestion to stay within a low budget would be a thunderbird 18 controller for that motor. you can get them for $25.
once again, the boat looks really cute so far, it should be fun finding out how it runs.
john
Old 07-28-2007, 10:25 PM
alloutcustom
they have an 18 amp on that site for the same price, it just isnt in stock, i was going to get that and plan on it when it is in stock.
Old 07-29-2007, 09:47 AM
alloutcustom
im still debating on whether or not to use rear sponsons. what do you guys think? someone said that you can use a bigger prop if you use them so i might.
Old 07-29-2007, 04:23 PM
spicedcrab
i would need to see a side profile picture of your hull to give my opinion on the sponsons, its hard to tell from what i can see from the other pics, i think you will need sponsons though to get enough hull out away from the waterline. i need to see the angle of the tub and front pads to see if it looks like it will plane or not.
john
Old 07-29-2007, 09:59 PM
alloutcustom
what are the pros and cons of rear ride pads?
Old 07-30-2007, 08:05 AM
crashbuilder
Very Nice .....
Never used these guys but they have some plastic Octura's including the X431
http://www.funrcboats.com/category.a...09&startpage=1
Old 07-30-2007, 10:19 AM
alloutcustom
ya i saw that but i was hopping they had smaller props
