Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
!!!!!!~~Radio help on sv27~~~!!!!!
Speed - Electric For all your electric boating needs.
Old 11-17-2007, 04:53 PM
ddmracing05
ddmracing05's Avatar
Default !!!!!!~~Radio help on sv27~~~!!!!!
Well my receiver is messed up on my stock radio so a friend loaned me a monster truck radio and receiver and It wont do anything! My old receiver... only cannel 2 works and I can either use steering or prop... not both. What radio can I get used or something? I dont have 75 for a new one.
Old 11-17-2007, 06:03 PM
ddmracing05
Default RE: !!!!!!~~Radio help on sv27~~~!!!!!
Well I got it working... Only steering is Throttle and Throttle is Steering. If i mix wires around and it does work at all. I took apart my controller to see if i could cross the wires in it but theres no wires on the throttle... ITs streight up to the board
Old 11-17-2007, 06:31 PM
Jonjoe
On your reciver swap the two round just make sure the Black/Brown wire is the outer wire closest to the edge of the reciver (your reciver channel should look like this (...) the dot on the far right is where the Black/Brown wire goes) thats all that can be rong with it if this dosent work take it back to your LHS and they should replace it under warrenty atleast the model shop i work in dose!
Hope this helps
Jonjoe
Old 11-17-2007, 09:10 PM
Avanti27offshore
ch1 steering
ch2 throttle
you can get a better radio on ebay rather cheap.
my stoc receiver and servo craped out after taking a dunk on my second run. Lucky for my I had a spare raio at the house.
Old 11-17-2007, 09:54 PM
ddmracing05
if i swich anythign around nothing works ... links to anything on ebay? I can find nada
Old 11-17-2007, 10:07 PM
ddmracing05
[:@]Well I hooked it up like you said... It kinda works but its messed up again. Throttle is back to normal but the steering turns as hard left as it can to the point where im afraid its going to break my rod or w.e you call it. and if I turn it in either direction you can hear the pressure comming off slightly but not enough to turn AT ALL
Old 11-17-2007, 10:27 PM
ddmracing05
Old 11-18-2007, 08:04 AM
Jonjoe
This sounds like a battery problem like not enough powers getting to your servo is it a nitro boat or electirc other than that it could be a Faulty Servo or reciver
Hope this helps
Jonjoe
Old 11-18-2007, 09:58 AM
LtDoc
This is a common problem with any proprietary system of any kind. It doesn't necessarily follow any particular 'standard' scheme except for the manufacturer's. Keeps 'others' from using -their- system for a cheaper radio, sort of.
There are two solutions, change to a 'standard' system, or find out exactly how 'their' system works and make it work. Both have disadvantages, time and learning, or money. Take your pick. There ain't no 'free lunches', but sometimes the 'price' is sort of variable... kind of.
Good luck.
- 'Doc
(If you can get 'them' to tell you exactly how 'their' system works, and it does, count your self 'blessed' to have been present during a "miracle"! Most manufacturers ain't gonna tell you...)
Old 11-18-2007, 10:02 AM
ddmracing05
well im a newbie so im clueless about radios.. Joejon it is a brushless. I know my servo isnt shot beacuse if I put my servo on the throttle on then it works just fine.
Old 11-18-2007, 10:13 AM
ddmracing05
Where can I buy a receiver???? I cant find them at tower hobbies and Off shore electronics only has aftermarket radios that im afraid to buy and wont work.
Old 11-18-2007, 10:36 AM
ddmracing05
now its not working at all... gah lee. Anyone know where I can get the Factory radio for this *****?
Old 11-18-2007, 10:54 AM
Silent-AV8R
Silent-AV8R's Avatar
What brand and model radio are you having trouble with??
Old 11-18-2007, 10:58 AM
ddmracing05
stockSV27 radio... Theres one on ebay for 5 bucks im going to buy.
This is killing me though... heres the water right now and I cant use it!
Old 11-18-2007, 12:33 PM
Silent-AV8R
OK. Just in case, have you seen this on the AquaCraft website:
http://www.aquacraftmodels.com/techs...qub17tech.html
Tech note on the SV27
Old 11-18-2007, 01:38 PM
ddmracing05
yea ive seen that. thanks though :/
Old 11-18-2007, 09:27 PM
ddmracing05
****... I forgot about the ebay crap and got outbidded! If anyone has a radio let me know.
Old 11-19-2007, 09:28 AM
cruisingcomet
cruisingcomet's Avatar
ORIGINAL: ddmracing05
See here: http://cgi.ebay.co.uk/New-Futaba-2PH...QQcmdZViewItem
Bought one of these off this guy & received it in the UK within 5 days, reccomend this guy highly!
Old 11-19-2007, 10:32 AM
ddmracing05
Yea but do you use it on a SV27 Without modifications and the stock ESC???
Old 11-19-2007, 12:03 PM
cruisingcomet
Im unable to run my motor to be honest as I have a crap SV27 that Ive been trying to get running for over a month now, despite Aquacraft support helping me its still not running, but the Futaba handset does turn the rudder no probs just as the stock radio does so i see no reason why it wont work fully.
Old 11-19-2007, 01:22 PM
ddmracing05
switch wires... Then your motor will work and not the rudder. Thats how its working for me.
Old 11-20-2007, 08:44 AM
cruisingcomet
What wires?
I have an intermittment problem with mine, its nothing to do with the radio for me anyway, sometimes the motor runs sometimes it wont & ive had this problem since day 1 of receiving this boat, getting pretty peed off although aquacraft think its the esc & are sending a replacment out its taking weeks.
Im 6 weeks into my 90 day warranty, almost $600 out of pocket & im still to see this boat run for more than a couple of minutes! [&o] maybe i just was unlucky and just got a dud but im really not impressed with my SV27 at all!
Old 11-20-2007, 04:03 PM
ddmracing05
yea I gotta order me or find something to seal my compartment off but not sure what to use.
