Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
Prince 25" Mono
Speed - Electric For all your electric boating needs.
Prince 25" Mono
Old 01-25-2009, 08:21 AM
  #526
Steve441
Default RE: Prince 25" Mono
Dremel worked great and I tinned the end to avoid the unravelling of the flex cable issue. Gonna bend the tube and do some initial fitting. I will post a pic to see if I got it right - Steve
Old 01-25-2009, 09:08 AM
  #527
h2oskier
I don't have any fiberglass cloth. Will the fiberglass epoxy hold the engine mount?
Old 01-25-2009, 10:14 AM
  #528
Steve441
Yes it will but the cloth is recomended - Vibrations are the enemy.
Old 01-25-2009, 12:03 PM
  #529
Basstronics
You can get a packet of cloth @ Wal Mart in the Auto section- about 4$
Use the fine weave NOT the strand mat.
Old 01-25-2009, 12:45 PM
  #530
h2oskier
Thank you I will grab some.
Old 01-25-2009, 02:10 PM
  #531
madphil
Just upgraded the motor to a 540 size 2500KV i seem to be getting a bit longer run time because i cant hold it on full throttle all the time like i could with the 380 size motor
phil.
ID:	1119254   Click image for larger version
ID:	1119255   Click image for larger version
Old 01-25-2009, 03:35 PM
  #532
785boats
Hi Phil.
Good to see you've got it running with the new motor.
Why can't you hold the throttle for very long. Does it become unstable or are you running out of water?
Paul.
Old 01-25-2009, 10:26 PM
  #533
madphil
Its on the corners i have to lift off now , this was the first time out with bigger motor i will have to play about with the strut and tabs now , with the old motor i could put it on full throttle and just steer round the course .
phil.
Old 01-26-2009, 06:39 PM
  #534
h2oskier
I went to put the propeller on today and noticed that it does not fit onto the drive dog. The propeller says TFL and I think the number is 435. The slots on the propeller that fit onto the drive dog are too small. What's the deal???[>:]
Old 01-26-2009, 08:44 PM
  #535
Basstronics
It fits on the shaft though?
Thats strange.
If you got a small file you could work it over some.
Old 01-26-2009, 08:46 PM
  #536
h2oskier
It does fit on the shaft, but I wasn't sure I should mess with it. Will it throw off the balance or is that just for the blades?
Old 01-27-2009, 01:46 AM
  #537
Tech Head
Tech Head's Avatar
Hey h2oskier,
Look deeper into this thread, it has been discussed before!
Cheers, Brett.
Old 01-27-2009, 05:20 AM
  #538
HSVXU6
Hi h2oskier, take your time and it will be fine. Been there, done that, read the book, bought the T shirt
Old 01-27-2009, 02:47 PM
  #539
sidav
does any body know were i can get any brass tubeing for the prop in the uk.
cheers
Old 01-27-2009, 08:54 PM
  #540
h2oskier
I will get a coffee and begin reading again thank you. [X(] You may tell me to read again on this one, but what is the easiest way to bend the copper tubing for the flex shaft? I can't find my tube bender.
Old 01-27-2009, 09:47 PM
  #541
dicko
dicko's Avatar
Heat it up, let it cool, stick the flex shaft in it & gently bend to the required shape. Alternatively tape one end fill it with salt & compact it in by tapping it on a table, tape the other end & gently bend it.
Old 01-28-2009, 01:18 AM
  #542
Tech Head
Tech Head's Avatar
Quote. I will get a coffee and begin reading again thank you. You may tell me to read again on this one, but what is the easiest way to bend the copper tubing for the flex shaft? I can't find my tube bender.
Here you go!
Find a close coil spring, like the springs used in campervan curtains.
You don't want a thin wired spring, get one that has thick wire and tight windings. (it helps to put some heatshrink tube over the spring, for easy removal later).
You need one thats a snug fit, but not tight.
Insert the spring into the tube and bend it by hand around something round, like a "beer bottle" or something simillar.
After you have the right bend, remove the spring.
Hope this helps, Brett.
Old 01-28-2009, 07:13 AM
  #543
Basstronics
Um...
I hope your joking about that spring idea... So someones going to take a large wire spring, shove it in brass tubing thats straight?
lol
Give it a try and let me know how that works for you!
I like the salt Idea. I will be using that since salt it CHEAP.
Old 01-28-2009, 04:43 PM
  #544
Tech Head
Tech Head's Avatar
No joke Basstronics,
I have used that method many times and it works well, just make sure it's a retention spring, not a compression spring!
What the spring does is keeps the tube round when it's bent. All tubes want to flatten out when they are bent and the spring stops that happening!
Cheers, Brett.
Old 01-28-2009, 04:50 PM
  #545
HSVXU6
Hi Basstronics. Down under here in OZ, plumbers use the spring method all the time. Heck you can even buy a kit with various size springs to all diam tube, got one in the workshop, about $15.00 Some do say that OZ leads the world with knowledge
Old 01-28-2009, 07:06 PM
  #546
Basstronics
Pictures or its a big lie!
I cant see how this would work well.
Old 01-28-2009, 08:27 PM
  #547
h2oskier
I went today and bought a spring used to keep a wooden screen door shut. I put the tube in the spring and it worked awesome. It bent my tube as needed and didn't crimp it a bit.
If my boat came with a 4mm flex shaft, what is the size of the motor shaft? I went to put on my Flex collet tonight and it appears to big. There is a lot of lay and when I tighten the set screw, it throws it off center. When I spin the motor, I can see that the collet is not centered and will throw one heck of a vibration.
Old 01-28-2009, 10:21 PM
  #548
madphil
h2oskier it looks like you have a 5mm collet , most of the bigger motors have a 5mm shaft you will need that when you upgrade your motor ,
phil
Old 01-29-2009, 01:07 AM
  #549
785boats
Hey Bass.
As an electrician ( also down here in Oz HSVXU6 ) we use a bending spring to bend PVC electrical conduits. Sizes 16mm, 20mm, 25mm & 32mm.
Our springs are inserted inside the conduit unlike the plumbers springs which are generaly over the outside of the pipe. The spring thing works large or small.
Cheers.
Paul.
Old 01-29-2009, 01:15 AM
  #550
Tech Head
Tech Head's Avatar
ooy! ooy! ooy!
