Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
Prince 25" Mono
Speed - Electric For all your electric boating needs.
Prince 25" Mono
Old 07-17-2008, 09:53 PM
  #51
FHHOBBIES
Default RE: Prince 25" Mono
Well I can't wait to see how yours does. Hope you have better luck.
Old 07-17-2008, 10:51 PM
  #52
FHHOBBIES
Are you able to measure the motor shaft and flex shaft for me as well? Just need to know what to order that will fit. That would be great! I am going to put my 75A ESC in here and try 4S again to see how long the motor will last[X(], I will also see if my LHS has a smaller prop.
Old 07-18-2008, 06:53 AM
  #53
Basstronics
I can measure it up tonight.
Im just taking a wild guess on the prop size here. Im pretty new to the hobby but it would make sense.
Now I need to find a good line on batteries. I was on E bay looking and Im not paying $25 to ship 2 little batteries. Know of anyplace good?
Im looking for 2200 Mah 20-25C 3s 11.1V
Old 07-18-2008, 05:00 PM
  #54
FHHOBBIES
You can try the 2200 but I am getting larger ones like 4000 or so, lots of room in there and runtime will not be very short and pack will not be hot. What brand of packs you like? Send me an e-mail and I will see what I can offer you. [email protected]
Old 07-19-2008, 05:36 AM
  #55
aussier6er
My Feedback: (-1)
hi guys
i also have one of these boats comming
it should arrive early next week
with mine i plan to run 11.1v 2200mah 25c lipos
has anybody ran one of these boats with this capacity batterys yet ?
what performance did you get ?
i may run it stock for a little then upgrade the motor and esc
Old 07-19-2008, 08:23 AM
  #56
FHHOBBIES
Yes I ran 3S 2070mah pack and got about 3min give or take, I will time it the next time out to be exact. My opinion is if you have those packs already try it but if you have to buy some get something bigger, besides if you upgrade the motor then you will need bigger packs anyway.
Old 07-19-2008, 09:24 AM
  #57
jacob711
check this out it looks like a good deal, the motor is probably a little on the small side but it looks alot better than what comes on the rtr version
http://cgi.ebay.com/25-deep-vee-kit-...742.m153.l1262
Old 07-19-2008, 01:40 PM
  #58
FHHOBBIES
Oh I wish I saw that sooner! lol I guess that motor would be 28mmx48mm like a Feigao 380 S motor? Or 58mm long perhaps, I will e-mail them, I may just order a couple of these boats and try them.
Old 07-19-2008, 11:14 PM
  #59
jacob711
http://cgi.ebay.com/2618KV-electric-...742.m153.l1262
here is the motor it think the specs say 27.6mm length and 58mm diameter but i think they got it the wrong way around
Old 07-19-2008, 11:43 PM
  #60
FHHOBBIES
Yeap I think I am going to order it and try it out, if it is still too small I will put it in my cat. Thanks for the find!
Old 07-20-2008, 12:56 PM
  #61
hpi_matrix
Im thinking of buying once of these with a 80A esc and 2200mah 11.1v lipo, would my only problem be motor temps? Wheres the best place to buy them from?
Old 07-20-2008, 01:21 PM
  #62
FHHOBBIES
If I were to do it again I would get the race spec version from here... http://cgi.ebay.com/25-deep-vee-kit-...742.m153.l1262 I think the main problem is the vibe issure which adds to the motor temp problem but yes the only issues I have with the boat so far is the vibes and motor temp, motor gets so hot you don't dare touch it, I burnt my skin bad just touching it for a split second... sizzle sizzle [X(] even melted the epoxy on the mount. I am going to upgrade my flex shaft and perhaps try the stock motor again to see if it helps the temp but will get a new motor anyway. Every place seems to be roughly the same, some places just offer different items, depends on what you want. I still say go with slightly bigger Lipos though but that is just me. Perhaps with a good working setup the 2200 will be fine.... dunno.
Old 07-20-2008, 01:58 PM
  #63
hpi_matrix
I dont really have the time or knowledge to build it so I was looking at an ARTR, what size are the mounting holes on the mount? Would a 540 motor fit straight on?
Im not after out and out speed, racing it just some fun before I go to uni, is this going to fit the bill? Or am I better off getting the jollymotor or something else?
Old 07-20-2008, 02:24 PM
  #64
FHHOBBIES
You would have to figure out a new mount or use the one off the race spec version, you will still have to cut out some of the rails on this version to get that mount in though, I am going to get one of those mounts. If this is your first boat I would not get it until all the issues are sorted, I would go Jolly or SV27, thats just my opinion though. This boat does not work right out of the box, at least my two do not.
Old 07-20-2008, 02:25 PM
  #65
FHHOBBIES
Or I could sell you my boats! So I can get the race spec!
Old 07-20-2008, 06:19 PM
  #66
Basstronics
Thats funny. I found that $170 one first but decided against it. I didnt want that type of out drive.
Hopefully towards the end of the month I can get mine in the water. need batts and receiver still.
Old 07-20-2008, 09:29 PM
  #67
FHHOBBIES
I have to order some packs soon as well, I get PolyQuest packs, let me know what you want and I may be able to hook you up with a good deal, I can also get some RXs, like I said I gotta order so let me know what you need and I will give you a price.
Old 07-22-2008, 02:53 AM
  #68
ozzie-crawl
can someone please measure the distance between the rails were the motor is ( in mm if possable ) as my boat hasnt arrived yet and i want to make a motor mount so i can put a 540 in it straight up. thanks
Old 07-22-2008, 02:58 AM
  #69
jacob711
i reckon the 540 should just bolt up to the stock mount, if not you probably only need to redrill or slot the mount holes
Old 07-22-2008, 04:06 AM
  #70
ozzie-crawl
yea going to leave the origonal mount there but put a 3mm alloy plate on one side to strenghten it up .if u drill holes for the 540 there isnt going to be much material between new and old holes
Old 07-22-2008, 05:12 AM
  #71
jacob711
you could just use washers
Old 07-22-2008, 05:57 AM
  #72
Basstronics
More measurements:
Motor Shaft: .125"/3.175mm
Flex Shaft: 4mm/.157"
Space between runners: Appears to be 44/45mm cant get in to measure it so had to eye it.
Please not the motor mount IS slotted. There are washers on it also. Allows you some flexibility.
Old 07-23-2008, 06:51 AM
  #73
ozzie-crawl
thanks basstronics. got the good news tonight boat is on its way
Old 07-24-2008, 08:12 PM
  #74
Basstronics
Heres a picture of the Flex shaft with the bent square end. I was able to bend it back into shape by hand. Think it will be fine.
Also note the square end could engage the propshaft more. Im only using about 1/2 the square on mine. Just beware of this when setting it up.
** pic attached but having some hosting/server issue obviously.
Old 07-24-2008, 10:20 PM
  #75
FHHOBBIES
Well R2Hobbies I don't think will replace my ESC I smoked. They told me to run it on 4S! They started off nice and all was well like they were going to replace it but then they just stopped replying to my e-mails![:@] Will not spend another cent there!
