ESC for Lead Acid Setup
FL
I'll be using a 550 brushed motor with 2 6V lead acid batteries. The total weight of the boat is about 16 Lbs.
This is in a tugboat and I will need reverse also.
Any suggestions would be appreciated
FL
This one should work etheir way (series or parallel)
http://www.offshoreelectrics.com/pro...rod=dh-prb2314
FL
Thanks Red [sm=thumbs_up.gif]
That was the one I looked at, just wasn't sure because other people are running 80 - 100 amp ESC's in thier tugs.
Tony
Tony
CA
The ProBoat ESC's are not known for their 'low end' revs, which you might be after if you are running a tug. They seem to 'cut in' at about 1/3rd revs.
Have a look at the Mtroniks range of ESC's (available in the USA from Loyalhanna) or the ESC's available from Harbor models.
FL
I'll check it out Toes. It's for my Springer and I trust your advice when it comes to them.
Tony
I tried to pull loyalhanna on the search and only come up with a town in PA. Do you have an address for it?
Tony
CA
ORIGINAL: fuelman8
By the way, a standard Springer is @ 8lb... my two super Springers top out @ 10lb... so @ 16lb, your Springer should be a submarine..
FL
Toes
Some one had told me that each battery was about 5 lbs so that was what I was judging the weight from. Guess I was wrong.[sm=red_smile.gif]
CA
ORIGINAL: fuelman8
Toes
Toes
