Norbert's 1.1m balsa cat build
#151
RE: Norbert's 1.1m balsa cat build
OK so I started another thread for my tunnel build here:
http://www.rcuniverse.com/forum/m_9539502/tm.htm
Please if you want to comment on my tunnel boat build, do it through the link above, thank you!
#152
I'm slowly getting close to finishing the plug for the cowl.
It still needs some more putty and sanding, then another layer of primer.
#153
beautiful Norbique!
you are an inspiration.
after you send me the plans, i start to build my cat. it's my first cat and it's going well.
how about the motors for the cat ? feigao?
i'm thinking in two kb45 for my cat, with all the modifications that i already saw in the forum. holes in the back, etc..etc.. what you think?
best regards and congratulations for the build
Juan
(bad english, sorry)
Juan
#154
Hi guys.....just wanted to drop an inspiring photo........you got to check the site out.....its cool, fast & wild.....the all new Miss GEICO....love the hatches...http://www.missgeicoracing.com/
Norbique....absolutly fantastic work man.....i didnt think it was possible in wood....wonderful stuff ......and a big thank you too....here's pic
#155
MN
ORIGINAL: norbique
I finished sanding the canopy and laid a layer of glass on it. A friend named it cockroach canopy because it somewhat resembles a cockroach, maybe he's right, I don't mind. the shape is about OK. It will look a little different once in place on the hatch.
How on earth were you able to lay a glass layer on that foam withut it melting/disovling on you? Ive tried a few different things, and everytime, the foam just disolves away. Nice work!
#156
Use epoxy resin instead of polyester resin, or buy a foam designed to be used with polyester resin from your resin supplier.
#158
I'm not sure if you have them in the states, but FGI (Fibreglass International) is a great supplier who I use here in Australia.
#159
WY
Hi my Nome is Marcelo I am From Brazil and is very hard to get that kind of work here, I am starting to build my boats my self because there is noboddy doing here, so I would like if you can tell me where did you get this project, it have a bigger size like 50" please if you have this project and like to help a fellow builder let me know [email protected]
#160
Hi guys, excuse me for I neglected the thread a bit lately. [sm=sleeping.gif] The Arneson drives are a huge expense. I am thinking on manufacturing my own.
The real reason for my pause in the cat build is my tunnel build. I though that would be cheaper, only one motor, one ESC, one battery, but I forgot that I have to buy the lower unit which costs a lot. either way, I'm working on the tunnel currently, but I didn't forget the cat either.
Juan, PM me you email address where I can send you the plans, and let me know the dimension you want the plans, hull length for example.
colosus, thanks for the picture it is really motivating, and thanks for the link and the nice compliments as well!
tc4 drft, yes I used laminating epoxy (very slow cure) to put the FG on the foam.
fmarcelo, I will scale up the plans to the size you requested and send it to the email address you provided. please be patient.
#163
Hello,
I am making a FE rigger, and i was wondering why you put foam in your boat? How does that help flotation and what if i dont leave that space empty?
Csak most vettem észre hogy te is Magyar vagy. Ritkán találkozni Magyarokkal akik ugyancsak ilyen hajókkal foglalkoznak. Te hol probálod ki a hajódat?
Nekem ez az elsö komolyabb használatra alkalmas hajóm. Ha bármilyen összejövetel vagy verseny van örömmel mennék. Egyébként 15éves vagyok. Minden segítséget elöre is köszönök!
All help isappreciated!
#164
Hi atcom, check your PM.
I was thinking about putting foam into the hull, people do that in order to help floatation if the boat is crached. The foam doesn't allow water to fill up all the space in the hull, thus saving it from sinking. At the end I didn't put foam in the hull. I decided I'd use air filled nylon bags, the ones that are put in boxes at the post. I can make a photo if you're interested. Your rigger looks good, what motor, ESC, batts are you using?
#165
My rigger is 90cm long, i use a 8T hurricane brushless set, and a hardcase 2s, 5000mah lipo from hk. Your boat looks amazing! My next project isdefinitely going to be a catamaran. I actually constructed my boat from fiberglass because the boats made from balsa and ply lookterribly hard to build! Did you have any detailed cad plans?
#166
PM me your email addy and I'll send you the cad plans for this cat.
ORIGINAL: atcom
My rigger is 90cm long, i use a 8T hurricane brushless set, and a hardcase 2s, 5000mah lipo from hk. Your boat looks amazing! My next project is definitely going to be a catamaran. I actually constructed my boat from fiberglass because the boats made from balsa and ply look terribly hard to build! Did you have any detailed cad plans?
#167
I did a short test with one of the TURNIGY 600 4030-1400KV motors:
[youtube]http://www.youtube.com/watch?v=txgiwsVM9xI[/youtube]
#168
Hi Norbert!
This thing should fly! Glad to see you have the 1400kv model as I have found the 1100KV really needs 8s to light it up... otherwise you have to prop the hell out of it.
Im going to order the 1400kv one for my sprintcat shortly.
Cheers
Matt
Cheers
Matt
#170
Sorry about that! I got your email address, but work got into my way. I'm gonna send you the plans tomorrow.
Matt: thanks for dropping by, I hope too these would make the cat fly.
ORIGINAL: atcom
Maybe i'm a bit rude but Norbert you haven't answered my PM
#172
Back to business, I ordered some water-cooled motor mounts for the big outrunners. The ones designed for the 540 size motors fit, but barely.
I'll have to enlarge he holes and slots for the motor screws. I took some mock-up photos, you can see the motor barely fits inside the motor mount. But it does!
#174
Thanks Cornel,
I'm doing my best to finish the cat by next spring. It's a slow process, but I'm not in a hurry. It's a hobby after all.
I just did a small spin up test with the motor mounted inside the motor mount. This beast has such a "strong" start up, I'm afraid it will rip the bottom of the hull apart
It has very strong magnets, but once it's running it's very smooth and creates so powerful wind, that it sounds almost like a turbine! Amazing motor for the price!
#175
Hi guys...i was without internet for 6 months so i couldnt see the forum...
Norbique... i havent started my Cat yet but was wanting to know how to change the size of the plan of the boat to 1m35 in CoralDraw....i know its a stupid question but iam new at Coral....also what do you think about making a mould from the wooden Cat ? and creating a fiber hull ?
