anyone know anything about this Ebay FE?
seems like a hell of a deal and just what im looking for.
includes BL motor and esc even
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
would like to run a 4S 5000 in it.
RE: anyone know anything about this Ebay FE?
Wow, nice boat at a killer price. It looks like it needs a BEC though.
I like the battery placement because it will allow you to run single packs. I might have to order one later down the road.
I have looked at that boat more than once myself...............looks nice, and all that beefy hardware hangin off the back..........and fiberglass...............seems like a decent deal...............just dont know anything about the motor.
Head of the river seems to be one of the better china suppliers. Boat is probably good. If you want to know more about the motor, look up thier other items. Usually the parts are available seperately and they will tell you more about them there.
Lots of people buy from them. Go through the boat and check everything out, odds are you will be OK. If not, you lose but you take chances at these prices.
Brian
Brian
The motor shows a website url on it. Here it is the motor(s): http://www.fsd-motor.com/en_products.asp?id=41
Click on any motor and download the speadsheet with specs on it.
Got in the hobby this year. I bought this one as my first boat. I'll tell you, I learned A TON - it served as a bad example
I recommend you buy the hull from Head Of The River and put an 8XL class motor in it and will spin at a healthy 31K rpms on 4S. As the boat comes, the 9L motor is over loaded trying to turn 2760 kv in a 32" mono. The ESC gets to DANGER levels (over 160) in about one minute of running at 4S. 6S is out of the question. 3S parallel might be best. Not 100% sure. Anyways, now I am re-buying the right motor/esc for this boat. I'd hate to see you go through the same thing.
There are no battery trays. Order up some 1/8th inch ply and center them at the 30% point from the transom.
Mine leaked like crazy. The stuffing tube was not sealed, probably a one-off issue.
My steering servo tray was poorly glued. Popped one day and took me out for the weekend... No biggie.
So, to repeat, a lot of this was me learning the hobby.
One tip that I will share, any time you get a new model, remove all the screws and threadlock them!
Also, consider dipping your electronics in Corrosion-x to repel water.
Check out this video of my Head Of The River Running with a Neu 1515 1.5y motor in it:
[link=http://www.youtube.com/watch?v=6x629MvhiSE]HOTR Delta Force 32 Clone[/link]
ORIGINAL: losifiend
IL
ORIGINAL: mickvk
Hi Mick
I think that will be my next boat!
