ProBoat Stiletto Tunnel Hull !!
My Feedback: (13)
KY
RE: ProBoat Stiletto Tunnel Hull !!
come on now is anything made in the USA anymore,even if they say that does not mean that all pieces are from overseas and just assembled in USA
Location: BROKEN HILLOutback New South Wales , AUSTRALIA
Hi Gasfreak [sm=thumbs_up.gif],
When i was a teenager in the late 1980's , i use to race BMX in Sydney Australia at club level . Having a U.S manufactured bike that meant that you had a quality ride , as most things iv'e ever known have been . Just tarnishes an item knowing it comes from a less than desirable country . Though it looks like it is well manufactered & i may buy hull & cowl in the future , i like the fact that Proboat sell individual parts .
Brad
Hey there Guys ! .... Just picked up my Stiletto this afternoon ! ...... Plan on running it tomorrow . Any pointers from people that already own and have run them ? I know it says to run it with two 2S lipos but how much of an issue would running two 3S lipos be ? I have an abundance of 3S batteries and just two 2S lipos . Obviously it's more voltage but will the ESC handle it ?
#31
got
www.rcuniverse.com/gallery/galleryItem.cfm
mine up to mid 30's with stock prop...got a x440/3 on there now havent tested it yet....thought id throw up a pic
#32
WA
I purchased the Stiletto yesterday, very nice looking. I will run these with Turnigy nano-tech 5000mah 2S in series. I wasnt prepared for the "sealed battery compartment" I guess it will work but not what I expected. I noticed the pull pull stearing cables are very close to the battery compartment cover, even touches the cover. Not a good idea and I say its a bad design. I plan on placing some tape where the cables rub on the cover to prevent the cable from diggin into the cover. I hope to get this trimmed out and have some fun.
#33
depends on what the esc is rated for, 4s to 6s is a pretty big jump, why not try 5 first? You could probably run 2 3s packs in parallel. Just looked up the specs, stock is a 1800kv motor with 60 amp esc, the voltage is not listed. I would say 6 s would be pushing it, I would test 5 first and see where you stand with heat.
#34
My Feedback: (20)
ORIGINAL: lapistola28
to run 5s you will need to disable the bec
stock with a prop change on 4s gets low 40s
runnig this hull on 6s without much experience will result in a upside down boat
