What prop could I buy for kyosho viper?
OH
I posted this in general,maybe the wrong forum? Can anyone help on what prop I can get to replace the stock one that broke on my older kyosho viper?
"If someone could link me to something on ebay of a prop I could buy for the viper that would be great,if not could you tell me what size or what could the stock prop. If anyone has a stock prop that they replaced with something more high performance and would like to sell me it,let me know. Im just looking to get the dust off it and get it back in the water"
RE: What prop could I buy for kyosho viper?
Hi Profit
I have a Electric Viper that is reworked to run 12 cells and a 700 sized motor. I may still have the orginal prop for it.I will have to dig it out. I think it would be easy to improve the performance with a lower kv 36 x 56 bl motor and bl esc. That size motor would still drop in on your existing motor mount. A 5mm to 4mm coupler and your almost done.
My modified Viper still has the submerged drive and is lots of fun. I did manage to win a race with it some four years ago.
If I can fine the prop ,its yours. I may have a few other Kyosho plastic props doing nothing.You can have them too.
n.h.schmidt
n.h.schmidt
OH
Thanks,that will help out alot
Its still bone stock with MSC,what good but cheap esc will work in the viper?
Hi Profit
I did find what I believe is the orginal Viper prop. I also have a Octura Y31 purple plastic prop that has been drilled out to 4mm.That should work too. Tower still sells the Duratrax Streak brushed esc. Under $35. Its a car esc that has been found to work very well in boats. Mine have even survived a good dunking and when dried out still worked.
n.h.schmidt
n.h.schmidt
