mini wild cat and mini hyrdoplane
RE: mini wild cat and mini hyrdoplane
here is the mini thunder i had it was ok but you can only run in ovals as it only turns good one way as all hydros do.... the mini Rio is a better boat.
here was my mini thunder with the electrfly T-400 hop up motot the one you should put in you boat.
http://www.youtube.com/watch?v=Z6Y_GTdJ6uk
