RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   hello newbee here (https://www.rcuniverse.com/forum/speed-electric-109/10074875-hello-newbee-here.html)
srt10 11-01-2010 12:28 PM
RE: hello newbee here
ORIGINAL: siberianhusky
I was sort of indifferent to electrics until a running buddy of mine got a used sv, stuck a 2300kv motor in it and a bigger esc, ONce we figured out the right prop and got things adjusted that boat rips. LOL I have gutted an older nitro hull and am doing a 4s mono! He changed my attitude with the SV. Good boat!
I've run one of my SV27's on 5s on the stock motor and esc and it was killer! :D
these can be a lot of fun when setup of right like yours
res3567 11-01-2010 08:43 PM
What is CF?
ORIGINAL: srt10
ORIGINAL: jride1999
ok thanx.i wanna upgrade my bat,everything is stock sept grim racer prop.im new to elect boats,always owned nitro car an this is my first boat. if i upgrade my bat,do i need to change anything else?
In my opinion not much needs upgraded on an SV boat
A good prop is always good.. I like using a CF45 and CF48 prop
I've also heard a S230 and S235 work amazing on this boat
And good lipos with a C rating of 30c and higher will give the boat more punch and speed with the bigger props
And always check your temps when you use a bigger prop to make sure things are running in the safe zone
And punch it!
srt10 11-01-2010 09:13 PM
Carbon props ;)
http://www.offshoreelectrics.com/pro...t=Carbon+Props
res3567 11-01-2010 11:27 PM
Ok....what about the GF props.....(Glass Filled)..........?
srt10 11-01-2010 11:29 PM
ORIGINAL: res3567
that's possible
