building the boats 75cm +/-
hello,
I am in the process of building the boats 75cm +/- it will be fiber glass. http://img2.imageshack.us/img2/2111/95013506.jpg I think of installing this like electronics : ESC : TR-M-120A - Turnigy Marine 120A Brushless Boat ESC moteur : HXT36-56-2700WJ - HXT 36-56 2700kv Brushless Inrunner (Wat.. lipo : T4000.3S.30 - Turnigy 4000mAh 3S 30C Lipo Pack servo : BMS-620MG - BMS-620MG High Torque Servo (Metal Gear) you think what of it? the other accessories I will order here: http://www.r2hobbies.com for can't Shaft + propeller + Fine/Stabilizer + the cap + Collet/Connector I what take? read that the shaft flexi fibre much? could you help PLEASE Thank you |
RE: building the boats 75cm +/-
You'll get better quality from OSE for hardware, props and cable drive:
http://www.offshoreelectrics.com/ |
Should be arround 30K with 3S, which is good, but at that legnth (almost 30") you may want to consider a 4S setup. I don't know what you desire for speed, but your options are better at 4S. Just my two euros. :D
