RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   direct or mini gearbox (https://www.rcuniverse.com/forum/speed-electric-109/10333079-direct-mini-gearbox.html)
badgerico 02-13-2011 10:36 AM
hi need some info
would using a direct drive i.e stern tube with shaft direct to motor via universal joint be less noisy than running it using a 2:1 mini gearbox?mini gearbox hasplastic gears and is noisy or is it that the gears are worn.
cheers
