RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   shockwave 26 brushless conversion , PLEASE HELP !!!! , URGENT !!! (https://www.rcuniverse.com/forum/speed-electric-109/10413382-shockwave-26-brushless-conversion-please-help-urgent.html)
dirt kicker 03-21-2011 05:57 AM
hi there guys
I have a Stock Standard Pro Boat Shockwave 26 , ( components )
1.) BRUSHED 550 Motor
2.)Brushed ESC
3.) Stock servo
4.)stock reciever
i REEEAAAALY wanna go brsuhless and have come across some inexpensive yet good deals , however , my concerns are : will this motor fit the Stock motor mount ? , what Prop am i gonna need ? what turning fins ? and is this too much power on a 26' boat ?
thanks alot guys !!!
http://www.hobbyking.com/hobbyking/s...idproduct=8594
http://www.hobbyking.com/hobbyking/s...dproduct=15132
shenlonco 03-21-2011 11:38 AM
RE: shockwave 26 brushless conversion , PLEASE HELP !!!! , URGENT !!!
they should work but the brushless shockwave 26 uses a 2900KV motor i would look for one in that range.
siberianhusky 03-21-2011 01:07 PM
I'd go for a 36mm motor and a 120 amp esc, that motor isn't to efficient, you'll be real close to the limit of that esc.
Check out the Tacon motors at Hobbypartz.com.
Most people are having good luck with the swordfish and turnigy 120 amp esc.
Soon as the water turns liquid again I have a swordfish 120 I'll be trying in a 1/10 hydro.
I'm not familiar with your boat but a 36mm motor should have the same bolt spacing as your 550 does. And be about the same diameter.
dirt kicker 03-22-2011 11:41 AM
thanks guys , !!!!
also can i run a 3s 4000mah lipo on the stock setup ? thanks
shenlonco 03-22-2011 02:28 PM
ORIGINAL: dirt kicker
thanks guys , !!!!
If you plan on running 3s get like a 2600KV motor
dirt kicker 03-23-2011 10:21 AM
THANKS ALOT BUD !!!!
Can i run Li-Poly on the stock Brushed system ? if so , what battry power can i be running ?
