prop Q
2 boats with the same electronics in the but each boat comes with differnt size props their shouldn't be a problem with using one with the other right ?
RE: prop Q
If different hulls the boat will not be as efficient assuming prop sizes are currently correct for each boat.<div>Check wih wattmeter if different hulls using a different prop could increase amp draw past a critical point</div>
| All times are GMT -8. The time now is 12:01 AM. |
