RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   Probat mystic 29 (https://www.rcuniverse.com/forum/speed-electric-109/11104890-probat-mystic-29-a.html)
curtqn2 06-03-2012 11:29 AM
Probat mystic 29
I've got a proboat mystic 29. When I go straight and fast the nose comes up and the boat flip over.
I try to change the CG. Move the prop up and down but it still doesn't work.
Any recommendation?
Dan S 06-04-2012 08:31 AM
RE: Probat mystic 29
1 Attachment(s)
put the batteries where they are suppose to go, set your strut the recommended hight and make sure you don't give it any positive angle.
lowering or raising the strut will adjust how wet or loose the hull is, prop angle will push the nose up or down.
you most likely have to much positive.
Dan.
Got RPM 06-04-2012 06:07 PM
Like Dan says, set it up like the instructions say and it will work. Put the boat on a flat tabletop to insure that the strut is in the correct position. One thought - how many and what kind of cells are you running?
