genesis help
when i run my boat out of water the shaft and prop wobbles but everything is tight and i cant see whats wrong i upgraded the shaft but i know something is wrong i also go the bushing that was needed but it still wobbles
RE: genesis help
if there is no play in the prop shaft, culprit is more than likely the prop is not balanced/incorrectly balanced.
Dan. |
