finding a prop?
I have an Atomic barb wire and would like to get a metal prop for it. I just want something as clos to the stock prop as I can get but metal. Any ideas? Thanks.
RE: finding a prop?
I'm pretty sure the original is a 430 composite prop, so this should be a direct equivalent
[link]http://www.offshoreelectrics.com/proddetail.php?prod=oct-x430[/link] |
RE: finding a prop?
Thanks ill check that out. Do you know if it comes sharpened and balanced or if I can get it sent thst way. I don't have the means to do it.
RE: finding a prop?
OSE has a separate listing for balanced and sharpened props - look there for the same prop number X430
RE: finding a prop?
I will thanks so much.
| All times are GMT -8. The time now is 12:18 PM. |
