Prop for 22inch cat?
hey im new here and dont have alot of rc boating exprience and it would be great if someone could help me out.
my question is what would be a good prop to run on a 22inch catamaran with a 3900kv seaking on 3s lipo? Ik it's high kV but it's the motor I have right now , hoping to make it all work out. Thanks |
What ESC do you have? You could start with an x432, but that motor would run better on 2S.
It's a seaking 60A , had this combo on 3s in a 16inch cat with a 30mm 1.4p prop and it flys , but it gets tiring going to flip it over 😂😂 just ordered a cheap 22inch cat hull and associated hardware hoping it will be much more stable in the water , plus maybe has some room to parallel 2 lipos for more run time, as long as the weight isn't to much.
Thanks for your help |
