RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   large scale motors (https://www.rcuniverse.com/forum/speed-electric-109/11687873-large-scale-motors.html)
keithcitra 02-18-2021 03:17 PM
large scale motors
i boat a boat named for pantera it is a v hull 46" long the boat is 10 lbs what motor will it take to push that much weight
Got RPM 02-19-2021 02:53 PM
Is the hull 10 lbs empty? A good sport set up is a large format motor (~56mm x 100+ mm) with a Kv around 800, run on 8S with a minimum 200 amp ESC. Props would range from 70-75 mm in diameter.
