ESC problems HELP!!
Hi
I have got an ESC from Graupner, the Power V60. When I had finished the electric wiring, I followed the instructions in the manual: " Set the throttle stick to the "full brake" position, and switch the transmitter on. provided that you have wired the ESC correctly, it will store it as the "full brake" position. The LED lights up to confirm this. To be sure of exact settings, wait until the LED goes out, then move the throttle stick to the "full throttle" position, and then back to "full brake". Your speed controller is now correctly adjusted. " When that was done I switched off the system (in the right way). Than I switched it on again and everything went perfect, but... When I came closer to the "full throttle" position the motor suddenly stopped. Of course I went confused so I tried again. I pushed the throttle stick towards "full throttle" but when it was very close to the end-point it just stopped, like before. -Is there somebody out there who knows what this may be???? -Is there someone who has got the same ESC???? Please help! / Tobias |
RE: ESC problems HELP!!
Hey Tobias,
What kind of transmitter are you using? If it's computertransmitter, the setting might not be compatible with the controller, for example, having the throttle channel at 125%. If there's no more reply here, mail Graupner and ask. Provide as much information as you can. ( [email protected] ) Regards, Jan. |
Okay, thanks Jan
[sm=drowning.gif] I'll try to mail Graupner |
| All times are GMT -8. The time now is 09:55 AM. |
