Setting up a new Trinity Monster motor help..
I got a new Trinity Monster Maxx Pro motor for my turbo vee 2... I also bought the trinity no solder leads... though I am not sure which of the 4 tabs on the motor I am to use for the no solder leads...any help?
RE: Setting up a new Trinity Monster motor help..
What esc are you using? If you still have the stocker, don't use it with that motor, you'll fry it!
That motor can handle up to 14 cells when properly watercooled and propped, but will still run ok with lower cell counts, just not as efficiently. Get a speed control with a higher amp rating (90A) to be on the safe side. |
i have a proboat waterproof esc that i am dropping in...any help on the original question?
nm...got the turbo vee all modded tonight :)
the end-bell of the motor should be labeled if you look real close. At least the + side will be. Also two of the tabs on each side are hooked together right? so there's a + and -
yup... finally saw the + ... just having 4 posts threw me off. Got it all modified last night.... hopefully this thing flies (not literally ;) )
Please let us know if it is faster ..
it better be faster ;) this motor is a beast.. ill be testing it out this weekend and hopefully get a video.
| All times are GMT -8. The time now is 03:59 PM. |
