LSH
What prop would you run with the climate models shovelnose with a 700 bb graupner with 12 cells
RE: LSH
Hi
I have several LSH boats and have seen many many others and how they are setup. For metal props You can't go wrong with these Octura X440 3, X442 , X445. X642, X645,M445 or M645. For Prather a P220 .For Graupner CF props a K42 ,K45 or K48. All of these will run your boat well. Some will not give top speed but, will give good speed and long runs. The X645 and M645 will give top speeds but is more demanding on everything .Batteriess,Motor ,esc . Your boat is a good one and can be very competive. n.h.schmidt |
RE: LSH
Hi
I have the same hull, but with ss1 (more torque, can wing larger prop) I would go for a x645 with a little strut angle, as the max prop on the graupner for oval racing, a prather 230 or a x647, or y547 will be good on ss1 for oval. for more runtime, just step down a bit in prop. |
| All times are GMT -8. The time now is 09:15 PM. |
