RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   Hammer servo reversing? (https://www.rcuniverse.com/forum/speed-electric-109/4162185-hammer-servo-reversing.html)
JimTMN 04-13-2006 06:49 PM
According to the manual if you click the servo reversing switch, the motor should turn in reverse. However when I do this, the motor simply bursts into hi-speed, then I've found I have to squeeze the trigger almost all the way to get it to reverse. For example if I am stuck and want to go in reverse very slowly, I cannot do this. Is this a bad motor/control or is there some adjustment I can make.
Also just to report, I just got done with my very brief 1st run of new Hammer EP. Very nice, however when I got back to the house I noticed blood all over my finger. I think I cut myself on the prop?! I had to pull a bunch of seaweed from it several times because it kept slowing down. I didn't know it was possible to get injured by a RC boat :)
n.h.schmidt 04-13-2006 07:04 PM
RE: Hammer servo reversing?
Hi
You shouldn't need to reverse the switch on the controller. Just push the trigger forward to reverse the motor.
You aren't in a whole lot of danger with a plastic prop and so low power motor. Now if you had a good sharp metal prop and more power then, you really need to look out. n.h.schmidt
JimTMN 04-13-2006 08:36 PM
Duh. Thank you. I figured it was something obvious :)
