RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   2 blade and 3 blade props (https://www.rcuniverse.com/forum/speed-electric-109/4685204-2-blade-3-blade-props.html)
joccee 08-29-2006 01:52 PM
If I have a 2 blade prop with the same diameter and pitch as a 3 blade. does the 3 bladed prop draw more amps and gives more speed?
CadillacDTS2001 08-29-2006 02:27 PM
RE: 2 blade and 3 blade props
it will draw more amps , , but probly not give it much more speed !
3 bladed are more surface area in the water ! so there is more drag !
joccee 08-29-2006 02:44 PM
okey. so theres really nothing to gainby using a 3 blade??
Dickey 655 08-29-2006 03:50 PM
3 blades will give you better pullout and might make the boat ride a little nicer, Its all how you want your boat to be.
BACKEMF 08-29-2006 04:22 PM
A crude rule of thumb for 3 blade props is if your boat runs well with a "Z" size 2 blade propeller, then if you want to run a more stable 3 blade prop, you need to prop down at least one size if not two. I.E; x640 2 blade is working good, then try a x437 3 blade.
Something like that. Sometimes in rough conditions going down in size but using 3 blades can be faster and more stable, the prop isn't out of the water as much and the torque effect isn't as strong.
