RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   550? (https://www.rcuniverse.com/forum/speed-electric-109/4837754-550.html)
CadillacDTS2001 10-12-2006 03:04 PM
RE: 550?
ORIGINAL: H2OCamel
Ryan I'm confused.
Are you saying that if I stick my 10x4.5x4 GWS prop in the water it will load the motor less than if I run it in the air?
of course
do you know what load is ?
with your hand make, it flat and push it in the air , . . its eazy rite
now put you hand in the water now and push is , . . . its harder, thats called load !! you have to work harder to move your hand , same as a motor it has to work harder to move the prop in the water then in the air ,
that is why it is no recomeneded to rev up motor with out load becuse it make excess heat and will burn up faster
ryan_t888 10-12-2006 05:25 PM
RE: 550?
ORIGINAL: H2OCamel
Ryan I'm confused.
I edited it to make it less confusing. Obviously everyone and their dog understands that air is much less dense as water. I believe water is about 800 times more dense than air
Ryan
