RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   SuperVee Glitching Problems (https://www.rcuniverse.com/forum/speed-electric-109/5241311-supervee-glitching-problems.html)
ralph289 01-10-2007 06:06 AM
We have a small club with about 7 SV's out of the 7 about 5 are or were having glitching problem, 3 changed to FM and glitching has been stopped. Just curious how many out there are running the STOCK transmitter & recever or have change or are having glitching problems. There are all fairly new boats and no water has gotten into the radio box.
Orange Crush 01-10-2007 07:37 AM
RE: SuperVee Glitching Problems
My first boat was totaled when the radio glitched. Went WOT into a concrete shoreline. Would respond to any input at all. It was replaced under warranty and I have the new one up on and FM Futaba.
Wheelnut 01-10-2007 08:43 AM
Welcome to the Futaba AM glitching club:D I have had two of these radios on different boats and they both glitched.
Got RPM 01-10-2007 10:23 AM
It is a shame that the maker chose to use a cheap AM radio with the SV, but it is easy to understand why - lower entry cost. AM radios regardless of brand are poor choices for BL-powered boats....they are more prone to interference and have limited clean range. Upgrading to at least an FM radio should be mandatory, and DSM is probably better. I had glitching problems with my FM radio and switched to a Spektrum - zero problems.
There are several things you can do to reduce AM glitching in a boat like the SV. Do not rely on the BEC, use a separate receiver pack in the boat. Make sure the transmitter pack is fully charged/changed often - do not rely on the meter on the transmitter to tell you if the pack is okay. Move the receiver and antenna as far as possible from the motor, packs and power wires. Keep any radio wiring - servo and ESC leads especially - as far away from the motor/packs/power wires as practical.
Blackjack52 01-10-2007 10:31 AM
Intended on changing the radio system before I even recvd the boat. I ran the stock radio one day. I had glitching and signal loss with every revolution around my lake.
Have installed Spektrum. No more problems.
dorkymk3 01-10-2007 01:12 PM
first thing i done to my boat was ripping out the crappy tx and rx and use a hitec srx agressor with a spektrum module and rx.
djr01974 01-10-2007 03:04 PM
yeah I had glitching problems also ... took out the am and put in a good fm no probs .
shenlonco 01-10-2007 03:20 PM
1 Attachment(s)
:eek:Hey i found this old FM Hitec Lynx think i should put it in my new super V27.....should be better than the stock am ...?
WHAT WOULD YOU DO?
Got RPM 01-10-2007 03:27 PM
Shen, what did you pay for it? You will need an FM receiver too, and by all means get the dual conversion receiver! I had glitching trouble with my Lynx3D with the single conversion receivers. The duals are more expensive, but well worth it.
shenlonco 01-10-2007 03:48 PM
1 Attachment(s)
Hi i had it laying around It has the stock FM reciever that cam with it....
Will this work or will it still get interfearance?
I have this but i don't want to buy another non crystal reciever for it and i always found i get my boat radios dirty alot and don't want this one to get messed up.
ralph289 01-10-2007 03:48 PM
Looks like we are not alone with the glitching problem, I am trying a new servo in my SV tomorrow but I'm just about sure it's not going to help and I will be on the computer ordering a FM unit when I get home [:@]
Wheelnut 01-10-2007 04:54 PM
ORIGINAL: shenlonco
I have the same radio. You don't have to by a synthesized receiver for that radio. If you want you could go the cheap route and buy a regular JR Receiver and a crystal. I like the Novak XXL because it is so small and the range is great.
shenlonco 01-10-2007 04:59 PM
1 Attachment(s)
Yea i thought of that also...
:D Look what i found good use for my stock S27 radio system for!
A crawler should be great for this radio beings it only runs about 8MPH or less!
tmaxx445 01-10-2007 05:37 PM
i am using my stock raddio ststem on my mini quake
Got RPM 01-11-2007 03:58 PM
Hi i had it laying around It has the stock FM reciever that cam with it....Will this work or will it still get interfearance?
It is better than any AM system, but for the best insurance against interference, get a dual conversion crystal receiver. I suppose you can try the single conversion first....you will need a dual conversion crystal too.
ralph289 01-11-2007 06:58 PM
Well after about 3 hours down at the lake I found the problem with my
SuperVee.
It would run fine with STICK (end to end) batteries but as soon as I ran
FLAT (side by side) pack batteries it would start glitching.
Sounds CRAZY I know. Tried it with SIX different battery sets and ALWAYS
glitched with FLAT packs only !
Finally used a friends FM receiver and Transmitter and boat ran fine with
ANY type battery pack. I also tried the STICK type in a friends Supervee and his
ran fine. So by what I can tell I believe my transmitter & receiver is the
problem (ran fine with FM) maybe it just need to be fine tuned or something
but there is something definitely wrong with it. I will ship it out
tomorrow for warranty repair but I also ordered a Futaba FM setup for the SV tired of messing with this problem.
Bet you never heard this problem before !!
Wheelnut 01-11-2007 07:27 PM
I used a side by side pack in my profisherman with the SAME radio and it always glitched.
ralph289 01-11-2007 07:42 PM
Yes I'm sure it not a very good Transmitter and receiver, but it is a GREAT boat ! But my problem sure is strange !
shenlonco 01-11-2007 07:43 PM
You should have tried rotating the stock reciever 90deg in the oposite direction...or laying it on it's side or something that might have worked.
ralph289 01-11-2007 07:51 PM
Yes that is a good idea, didn't think of that. Had so many things going through my mind on this problem. Well I for sure won't have any problems with the FM set-up. One less thing to worry about .
Wheelnut 01-11-2007 08:36 PM
ORIGINAL: shenlonco
Here is the scenereo that shenlonco is suggesting.
So you rotate your rx 90 deg and put the boat in the water to test fate and all of a sudden your boat takes off and hits the brick wall or dock and smash [:@] need I say more. Or how about this, you run your boat till your warranty runs out and all of a sudden one day while you are running your boat in a lake you never ran it in before that has some interference and same as above.
Just take the knowledge you have, that some people have had boats get smashed because of a radio glitch and that some people have not had problems at all and make the decision of what you want to do.
To be or not to be, that is the question.
ralph289 01-11-2007 08:54 PM
Good point Wheelnut, That is why I'm going FM. Just can't trust the way the Stock set up is working. Better safe then sorry !
shenlonco 01-11-2007 10:11 PM
:DAnother good idea that works is to use one of the bags for sensitive electronics anti static bag put your reciever in it and it won't let outside electronic static electric waves interfear with it... this worked for me on some of my RC cars.
Wheelnut 01-12-2007 08:16 AM
ORIGINAL: shenlonco
Thats an interesting theory, but it does not eliminate the fact that your antenna is still the main part of the receiver that receives the interference.
shenlonco 01-12-2007 09:44 AM
No sometimes it's the parts on the reciever board this is why with RC Cars or nitros they say if you get interfearance try standing the reciever on its side rather than flat ...I did the trick above a few times and it worked.
