Hammer: Surface Drive..
What do you guys think will happen?
I converted my hammer ep into a surface drive, with the hardware from an aquajet. Its got a 600 multiplex, 2-7cells. How do you think the hammer will run with a surface drive? |
RE: Hammer: Surface Drive..
i have noting else to say other then it will not work properly.
do a search on this topic. |
I'm sorry Taylor, but I still disagree with you on this one. There was a guy that had a whole thread on this subject and it was a successful conversion. The bad thing is that the thread got deleted with a RCU System upgrade, like one of my threads did.
ORIGINAL: Wheelnut I'm sorry Taylor, but I still disagree with you on this one. Mr verado. do it and prove me wrong. |
Or someone help me find a real cheap hammer hull and I will do it. I have a brushless motor and a brushless esc just itching for a new project, and this is one I have been wanting to do for a while:D
ORIGINAL: Wheelnut Or someone help me find a real cheap hammer hull and I will do it. I have a brushless motor and a brushless esc just itching for a new project, and this is one I have been wanting to do for a while:D LOL |
haha, actually the profisherman did handle pretty good, all I needed to do is to shift some more weight to the back. other than that it actually handled pretty good. Check it out verado
http://www.youtube.com/watch?v=VEFgke5_oP4 |
ORIGINAL: Wheelnut haha, actually the profisherman did handle pretty good, all I needed to do is to shift some more weight to the back. other than that it actually handled pretty good. Check it out verado http://www.youtube.com/watch?v=VEFgke5_oP4 |
Very nice.
So far i have everything ready to go, everythings mounted. All i need to do is wait for my battery for the esc to come in and patch a hole on the bottom and shes ready for a test run. Ill get some pics up later tonight. |
ORIGINAL: Taylor Shaw ORIGINAL: Wheelnut haha, actually the profisherman did handle pretty good, all I needed to do is to shift some more weight to the back. other than that it actually handled pretty good. Check it out verado http://www.youtube.com/watch?v=VEFgke5_oP4 |
ORIGINAL: Wheelnut ORIGINAL: Taylor Shaw ORIGINAL: Wheelnut haha, actually the profisherman did handle pretty good, all I needed to do is to shift some more weight to the back. other than that it actually handled pretty good. Check it out verado http://www.youtube.com/watch?v=VEFgke5_oP4 |
ORIGINAL: verado Very nice. So far i have everything ready to go, everythings mounted. All i need to do is wait for my battery for the esc to come in and patch a hole on the bottom and shes ready for a test run. Ill get some pics up later tonight. |
ORIGINAL: Taylor Shaw ORIGINAL: Wheelnut ORIGINAL: Taylor Shaw ORIGINAL: Wheelnut haha, actually the profisherman did handle pretty good, all I needed to do is to shift some more weight to the back. other than that it actually handled pretty good. Check it out verado http://www.youtube.com/watch?v=VEFgke5_oP4 |
My sunstorm worked well when I converted it to surface drive the main thing that affected performance is prop choice.
I have been thru 6 different props and 4 of them wont evan move the boat faster than about 5mph. (cavitate real bad) Yet 2 of them work very well and get the boat up to 30mph. Heres the thread http://www.rcuniverse.com/forum/m_5325139/tm.htm |
ya i might convert my turbo vee 3 just for the heck of it. lol. at least it is sumthing to do!
ORIGINAL: verado Ill get some pics up later tonight. |
OT guys i know But a Q for Taylor, Where can i find a tranny for 2 540size motor's?
ORIGINAL: BB Modss OT guys i know But a Q for Taylor, Where can i find a tranny for 2 540size motor's? I made my own a while ago with the use of a FDM tranny. it worked out rather good. I used the original front plate where you mount the motor and then made a large plate that would hold both motors. I then made it so that they will adjust on the original track for the one motor that was supposed to be mounted on. Make any sence? If not i will get a pictures. |
Id like to see a closeup if you dont mind.
This is supposed to be a PM
but I thought it might benefit other people. Its quite simple indeed. http://i152.photobucket.com/albums/s...tormount-1.jpg |
Thanks Taylor,
Verado, I just picked up a Nitro Fiberglass Hammer hull for $50.00 shipped. It should be here in a couple of days. I am going brushless with surface drive. I will start another thread and I will also need some help. |
ORIGINAL: Wheelnut Thanks Taylor, Verado, I just picked up a Nitro Fiberglass Hammer hull for $50.00 shipped. It should be here in a couple of days. I am going brushless with surface drive. I will start another thread and I will also need some help. |
ORIGINAL: Taylor Shaw ORIGINAL: Wheelnut Thanks Taylor, Verado, I just picked up a Nitro Fiberglass Hammer hull for $50.00 shipped. It should be here in a couple of days. I am going brushless with surface drive. I will start another thread and I will also need some help. |
ORIGINAL: Wheelnut Don't be so eager to discredit an innovation:eek: ;) |
ORIGINAL: Taylor Shaw ORIGINAL: Wheelnut Don't be so eager to discredit an innovation:eek: ;) |
| All times are GMT -8. The time now is 05:35 AM. |
