Modded Mini-V's
please post vids here if you've got em!!!
If not, pics and speed estimations are cool! |
RE: Modded Mini-V's
1 Attachment(s)
Since the props are gllued to the shaft, I have made some prop/shaft upgrades. I have made two. One 31mm that has more pitch than the stock 31mm. And a 33mm. I have also made a 7 cell battery upgrade. I had to modify the battery tray to get it to fit. Here is another pic of the 31mm prop/shaft combo installed.
I emailed Proboat and they said, and I quote "Thank you for your recent email. I do not have any additional information about the prop as of yet, however the prop comes included in an assembly PRB3013. The prop is most likely threaded on to the shaft". However, I am pretty sure he is wrong. I tried to unthread it and it didn't want to budge. It might have lock tight on it. But I didn't want to break it before I at least ran it stock one time. I made that mistake with my SW26 a long time ago. I never ran it stock. |
RE: Modded Mini-V's
are we the only people out there modding these things Ive got a mamba brushless a teamlosi fm radio an octura 427 prop and a 910 mah lipo in it it has enough power to jump out of the water on 1/2 throttle and probely does about 40 mph I,ll be able to run wide open after I put in some trim tabs I,ll post pics once I figure out to to use the darn computer.
RE: Modded Mini-V's
Hey Animalnut
Where in Chesapeake do you run you boats? |
RE: Modded Mini-V's
back behind Indian River high school theres a nice lake .It has a full course set up and a nice dock to launch and retrieve from
RE: Modded Mini-V's
ya I have a AON thruster 3300KV in my mini V I am having some trouble but it will hit the water agian soon
RE: Modded Mini-V's
what kind of problems are you having with it.
RE: Modded Mini-V's
OK I took it out again this time a little more brave than last long story short half throttle about 40mph full throttle it becomes mini plane then mini skipping stone then i bobs up and down for ten minutes before blowing back in I hope the electronics dry out if not I,ll have to go get more look,s like debbie,s r/c world will be getting some more of my hard earned money I,ll post more soon.@#%$#%&*
RE: Modded Mini-V's
Are you ever going to get some pics and vids for us? Sorry to hear about the water, Tape, Tape, Tape
RE: Modded Mini-V's
my wife said she would give me a hand posting some pics the good news is all the electronics are dry and work thank god for that it will be up and running in no time but this time I will waterproof everything!!!!!!!
RE: Modded Mini-V's
ORIGINAL: animalnut my wife said she would give me a hand posting some pics the good news is all the electronics are dry and work thank god for that it will be up and running in no time but this time I will waterproof everything!!!!!!! |
RE: Modded Mini-V's
1 Attachment(s)
I figured it out
| All times are GMT -8. The time now is 12:58 PM. |
