RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   super vee (https://www.rcuniverse.com/forum/speed-electric-109/5909503-super-vee.html)
alecat88 05-27-2007 08:01 PM
super vee
1 Attachment(s)
I added adjustable trim tabs relocated the antenia
MsDarla 05-27-2007 09:41 PM
RE: super vee
Installed by me. ;)
Watch out for my boat. [sm=drowning.gif]
FE_Chris 05-27-2007 10:29 PM
RE: super vee
Looks nice al. Wonder where you got the antenna idea ;)
I dig those trim tabs. Niiiiiiiiiiiice....[8D]
UTAviolist 05-28-2007 12:27 PM
RE: super vee
if you don't mind me asking, how exactly did you mount the antenna. I assume the white part is a dubro landing gear strip but what else did you do?
CadillacDTS2001 05-28-2007 02:25 PM
RE: super vee
ORIGINAL: alecat88
ok . . .
GRANT ED 05-29-2007 01:49 AM
RE: super vee
ORIGINAL: Taylor Shaw
ORIGINAL: alecat88
ok . . .
Was kinda thinking the same thing.
alecat88 05-29-2007 05:32 PM
RE: super vee
small rubber hose so it would have a tight fit, drilled a hole side of radio box ran the antenia, filled the holes in the radio box and the hole with hot glue, i had broken the radio box antenia mounting area. yes I got the idea from FE_chris's boat. I also got a X440 prop but still need to polish it
alecat88 06-04-2007 09:52 PM
RE: super vee
polished the prop easier then I thought it was going to be
alecat88 06-10-2007 07:07 PM
RE: super vee
With the new prop got 32 mph with a GPS. almost flipped it end over end until I got the trim tabs adjusted. I can say its alot more stable. The supervee is one of the best bang for the buck boats I've ever owned.
Wheelnut 06-10-2007 09:36 PM
RE: super vee
Just curious, Have you seen this thread?
http://www.rcuniverse.com/forum/m_4752309/tm.htm
alecat88 06-11-2007 06:33 PM
RE: super vee
I did not see if before now , thanks
