RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   Silly question (https://www.rcuniverse.com/forum/speed-electric-109/6119674-silly-question.html)
verado 07-16-2007 08:05 PM
Silly question
Ive never seemed to have this problem. But my new 7.2v 3800 packs make my sv run like 5..10 mph less than my older 7.2v 3500mah packs. I emailed the guy to see if they were defected and he said the batteries need to be cycled 3-5 times. What does that mean and how do i do so?
D-White 07-16-2007 08:08 PM
RE: Silly question
so how fast were the 3800's running? cus I am running Duratrax 4200's and they are great,did you balance the batteries,and mine are in shrink wrap if that means anything? try that,and make sure they are on a FULL charge!:)
alloutcustom 07-16-2007 08:17 PM
RE: Silly question
if your chargewr has a cycler then use that(read the manual) or if it doesnt then you can discharge them using a lightbulb set up.
cycling simply means charging and discharging but dont discharge at full amps until they are cycled. i am pretty sure you dont want to charge them real fast either.
verado 07-16-2007 08:52 PM
RE: Silly question
hmmm ok. thank you guys ill give it a shot. do you think that will be a solution? To be honest, i dont quite know how fast it goes i would say mid 30s easily with the grim prop. But with these new batteries its much slower. Guess i should order a gps too.
alloutcustom 07-16-2007 09:34 PM
RE: Silly question
that happens with all batteries. your runtime will be shorter and not as fast until you have cycled them.
