RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   Final Plans for a Fast Cat (https://www.rcuniverse.com/forum/speed-electric-109/6153392-final-plans-fast-cat.html)
bebopin64 07-25-2007 02:39 AM
Ok I've pretty much decided what I am going to build.
Drifter S Cat
Nemesis XL Brushless motor (what turn should i go for?)
Castle Barracuda 125
6C (3+3) liPo battery (what mah is good for this size?)
FDM 8-16 cell Hydro Complete Hardware Kit (can it handle the power?)
Not sure about prop size, thinking CF for price
Have a radio with a metal gear high torque servo
I am really hoping this thing will scoot, what kind of speeds can i hope for?
I should have it build before august 11 if im lucky, otherwise the weekend after.
bebopin64 07-25-2007 07:27 AM
RE: Final Plans for a Fast Cat
ok fecalc is telling me ill get 57.6mph with a 7xl motor and a 32mm prop which just seems ludacris
ryan_t888 07-25-2007 07:30 AM
Do you mean a 6 C discharge rating on the lipo cells? And only 3 cell lipo paralleled? Which packs do you have in mind. FEcalc tends to overestimate current draw and speed.
RYan
bebopin64 07-25-2007 07:53 AM
i dont know about discharge rate, i dont know what batteries to use. i meant i want to run 2 3cell packs in a series for 6 cells total.
ryan_t888 07-25-2007 08:03 AM
Are you still running twins?
Ryan
bebopin64 07-25-2007 08:19 AM
no just 6 cells to one motor
bebopin64 07-25-2007 08:57 AM
ive decided just to buy the 6cell lipo from finedesignrc so know i just need to know which turn motor i should use. would a 6xl draw too much? i just dont know much about brushless motors yet.
alloutcustom 07-25-2007 09:10 AM
you may want to try a 9-10xl if your running a 6-cell lipo. i dont know this for sure but i think that it may get fairly hot. someone correct me if im wrong. i realy dont want him to do the wrong thing because of me.
ryan_t888 07-25-2007 09:11 AM
A 6XL will be a very hot setup on anything more than 4 cell lipo. I'd recommend looking at something around 9-10XL and propping the motor very light.
Ryan
bebopin64 07-25-2007 09:13 AM
so maybe a 9xl and a 42mm prop?
ryan_t888 07-25-2007 09:22 AM
I personally would start with a 37mm prop and work my way up. A 6 cell boat will be a hot setup. Care must be taken when testing the final outcome. Constant temp checking is a must. Proper and efficient cooling is also a must.
Ryan
bebopin64 07-25-2007 09:25 AM
i will be using the offshoreelectrics cooling jacket made for the fiagaos and a rudder water pickup. i assume the esc will need cooling, how should i accomplish this?
bebopin64 07-25-2007 09:26 AM
and i changed hulls again. i want to use the mean machine hull now. will it be much slower with the added 3.5"?
ryan_t888 07-25-2007 09:30 AM
By picking up the cooling plates offshore sells for the ESC. No the 3.5" extra is good.
Ryan
bebopin64 07-25-2007 09:39 AM
theyre sold out of the esc plates. could http://www.offshoreelectrics.com/pro...qub9212&cat=75 be made to work?
ryan_t888 07-25-2007 09:48 AM
The 2 ESC's have different dimensions. I'd wait untill the plates are in stock or make up your own.
Ryan
bebopin64 07-25-2007 09:51 AM
this guy is running basically the same boat. it has a 12xl and a 3blade prop. http://youtube.com/watch?v=vGVdNT76M0w
ryan_t888 07-25-2007 10:18 AM
He is in here once in a while and goes by the name Orange Crush.
He is running a 37mm prop using a 12XL and 6 cell lipo's. I'd try and mimic his setup as you would get more runtime out of it.
Ryan
bebopin64 07-25-2007 10:37 AM
should i just flat out copy the motor and prop?
ryan_t888 07-25-2007 10:48 AM
Go with a 2 bladed prop around 37/38mm and use the 12XL. The 12XL has a MAX of around 55A according to the charts, you may get away without water cooling on the CC125 but you must prop it light - 37mm, 2 blade. I'd shoot a PM off to Orange Crush for question such as hardware ect.
Ryan
bebopin64 07-25-2007 12:05 PM
alright i ordered everything after talking to chris at finedesign a bit.
i got mean machine hull
nemesis blue 12xl
CC Hydra 120
3700mah 6cell lipo
FDM hardware kit
35mm CF 2blade prop
im going to test and retest the watercooling before even plugging in the battery.
FE_Chris 07-28-2007 11:53 PM
hey did you ever build this? How is it? Sounds like a hot rig.
bebopin64 07-29-2007 12:01 AM
still waiting on parts. the last of them will be in on the 1st, just in time for a 2 day drive back to texas.
bebopin64 08-01-2007 07:41 PM
so its the first and only one of my boxes came in. so now on my way from CO-->TX im going to stop at the UPS store to get the other one. now i have to wait until i get home to build it...sigh
bebopin64 08-02-2007 01:46 AM
pics of the hull.
I am seriously thinking about not using the hatch and making a flat clear lexan one. i think it would be cool to see all the electronics and it seems like being flat would make it faster due to increased aerodnamics.
http://www.geocities.com/bebopin64/boat1.jpg
http://www.geocities.com/bebopin64/boat2.jpg
http://www.geocities.com/bebopin64/boat3.jpg
