RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   Looking for an outborad Electric (https://www.rcuniverse.com/forum/speed-electric-109/6259709-looking-outborad-electric.html)
cdxanti 08-19-2007 07:09 PM
1 Attachment(s)
hi everybody i need help finding a outboard motor part. i have a motor. i just need a way to go from vertical shaft to horizontal shaft.
ryan_t888 08-20-2007 12:48 PM
RE: Looking for an outborad Electric
Purchase a new Outboard motor. Either one from Graupner or the EP1
Ryan
CadillacDTS2001 08-20-2007 02:40 PM
REK OB: http://www.drcwebservices.com/ffe/hardware.htm ( go down )
or a cut K and B ( don't recommend if you can't use a band saw.
cdxanti 08-22-2007 05:01 PM
I have a K&B lower half for a 3.5 how would i make that work
ryan_t888 08-22-2007 08:08 PM
There's a lot of material you can cut away on the K&B. Take out all the exhaust above the aeration plate and cut pretty close to the screws on the lower unit up to the engine mount.
You will need to make a motor mount to connect your motor up with flex. You can do this by cutting in to the lower unit deep enough for a coupler or you can just raise your mount high enough to fit a coupler in between the lower and motor.
Either way, I'd recommend getting a new motor. At least a brushed 700 size can.
Ryan
cdxanti 08-22-2007 08:10 PM
where could i find a coupler and the motor i have is from a rc monster truck is it still not powerfull enoth
ryan_t888 08-23-2007 07:49 AM
It depends on what coupler you will end up needing.
Your motor looks like a stock 550. Is it a 700 size or bigger brushed motor? If you want 25+mph out of the OB, you will need atleast 700 power.
Ryan
cdxanti 08-23-2007 04:00 PM
its a stock 550. i just want to get the boat moving i dont really care how fast it goes as long as it dosent crawl
