RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   Hydromite setup question! (https://www.rcuniverse.com/forum/speed-electric-109/6343133-hydromite-setup-question.html)
baldwinc 09-08-2007 02:34 PM
Hello all,
I'm in the process of building a hydromite, and I'm trying to use existing equipment from my airplanes to power it. My question is, I am using a Typhoon 2w-20 from an EDF plane (3350Kv, 28mm can), what would be a good starting point for prop/battery? I'm planning on using 3s, either 1320 or 2100, but where should I start with props? Also, what would my run times be (approx) with either the 1320 or 2100? I appreciate any help you can give!
Thanks in advance!
