Killer BJ FE conversion
I picked up a NIB BJ26 today, guy said his son didn't want it (more likely he stole it) anyways i gave him $50 for it and off i went, iv got every thing pulled out except stuffing tube and stringers,I built some carbonfiber battery holders in the 2 large areas beside were the motor used to be,put foam under the boxes for support and flotation, Battery boxes are 100% waterproof at this time! Now im looking for a 3/16th's strut with a skeg on it, any source for it? and i have a rudder on hand! Iv built 4 4s2p 8000 mah Lipo's for the hull, fitted with with a 9l and x640 prop it should run decent for a sport boat!
RE: Killer BJ FE conversion
ORIGINAL: BB Modss I picked up a NIB BJ26 today, guy said his son didn't want it (more likely he stole it) anyways i gave him $50 for it and off i went, iv got every thing pulled out except stuffing tube and stringers,I built some carbonfiber battery holders in the 2 large areas beside were the motor used to be,put foam under the boxes for support and flotation, Battery boxes are 100% waterproof at this time! Now im looking for a 3/16th's strut with a skeg on it, any source for it? and i have a rudder on hand! Iv built 4 4s2p 8000 mah Lipo's for the hull, fitted with with a 9l and x640 prop it should run decent for a sport boat! octura carries strut with skeg, check it out. |
id like billet..not cast, good eye though!
I run the octura one on my renegade rigger, it neeed a tidy up with a fine file, i've had no issues with it. you can polish them up if you want it to look bling.
Well i guess thats the route i shall have to go! Thanks
$50.00 !!!! I'll give you $60.00 for it!:D His kid didn't whant it, yeah right:eek:.
50 bucks ! Good deal! post some pics ! I bet the guy doesn't have any kids , probably smoken up that 50 now!!!
Yea im sure it was a $50 rock he was after, not a present for his "kid". Ill snap some shots tomorrow! Might have to swap forums, cause i might just swap back to a cmb nitro .21..found a valvola on ebay...always wanted one of them for my collection...
i put fullers cat hardware on mine. 8xl 120 hyrda on 4s=52mph on mine its the nitro one i converted to FE............:D
not to shabby! ill be running a NEU 1515/1y, on 4s2p
Imo i think thats too much motor for that hull might be too small but try it and let us know.......:D
nitro? come on its need electric power. Its not much better to work with. not to mention neater and clean
Hope it works out |
The 1515/1y is not to much motor, Its just right with a y535 on 4s.
there is no such thing as to much power! or motor
well lets see what kind of speeds you get........:D
1 Attachment(s)
BBMODS, here's a shot of octura strut with skeg, needs polishing though but i think it will look great with polished and shiny prop...btw, this thing needs bearing when ordering..hope to see a nice result..;)
Oh that, I had ones of those ( the larger ones) and it bend very easily. I don't know if mine was a bad one or what, But it wasn't very durable.
Beryllium copper is hard, if yours was soft there was something wrong.
Yea,
At least comparing my Alum vs. Be/Cu props the Aluminum was way less durable. Also way lighter. In the case of running hardware I'll stay with aluminum as it's ligher and seems to hold up to the task. BE is for props! I will go to Octura for h/w on my first scratch build as the price is right (and it will get polished) |
ORIGINAL: BB Modss Beryllium copper is hard, if yours was soft there was something wrong. |
Iv got a older Octura strut here thats Be/Cu Didn't know if they were still making it that way.
BBmods - Not sure if this is 3/16...[link]http://www.rossisales.com/strut.html[/link]
Also, Ray Fuller has a skeg option on the strut for his mini hardware kit. |
LOL i linked him that 2 days go!
I tried.
lol,
it was by fluke actually. I was surfing to buy some new hardware and i came across it, and sent it to him. ! |
| All times are GMT -8. The time now is 07:13 PM. |
