RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   HELP mounting motor and esc please!!!!!! (https://www.rcuniverse.com/forum/speed-electric-109/6812654-help-mounting-motor-esc-please.html)
bree9482 12-27-2007 06:05 PM
Hi guys thanx for reading, anyways i just got an rc boat as a gift for chrimbo. I decided to strip right down to bear it the nqd 757 high wind. the reason was so i could upgrade with an esc and faster motor and add a rudder system. i have got all parts now and i dont know how to put them in hull. i am a complete novice with boats. i bought an motor mount but it does not line up with holes in boat already. im really stuck someone pls help!
cheers
DRAGONFIRE81M 12-27-2007 06:28 PM
RE: HELP mounting motor and esc please!!!!!!
man i could explain two ways of mounting but i dont know what the inside looks like . but you could look at the tread on the boat heres a link .
http://www.rcuniverse.com/forum/m_3361236/tm.htm
bree9482 12-27-2007 06:37 PM
thanks for your speedy reply dragonfly i was just looking at that. i think im gonna get some wood and just screw down to exsiting holes and the that will give me a flat base to choose places for everything. i think i have bought the wrong type of rudder can u tell me which i should go for and any info u might think will help
cheers
DRAGONFIRE81M 12-27-2007 06:59 PM
what kinda rudder did you get . make sure you water prof the wood . i didnt do it on a servo mount and the wood split in two under the stress after it had gotton wet .
bree9482 12-27-2007 07:03 PM
just one from the local model shop but its nothin like the ones i see on here i need to get on that come away out do the come as kits like with the strut brace and all conections and silly question how do you waterproff the wood and will all the electrics be ok i thought the inside would be watertight sorry what kind of glue do i get to waterproof the prop holes?
DRAGONFIRE81M 12-27-2007 07:27 PM
even watertight your still going to get some water in over time the wood is going to suck it up . for filling in the old prop holes just use some epoxy. go to http://www.offshoreelectrics.com/categories.php?cat=17 youll find some nice rudders here
bree9482 12-28-2007 06:31 AM
cheers dragon fire i can now at least see how will come together and thanks for the link if u have anymore suggestion pls just let me know im open to any form of critisism cheers
DRAGONFIRE81M 12-28-2007 06:48 AM
your welcome bree . if you can try to post some pic's love to see her when shes all gone
bree9482 12-28-2007 01:24 PM
NO PROBS hoping to maybe have it finished for mid january all going well cheers!
