RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   Brushless Motor question?? (https://www.rcuniverse.com/forum/speed-electric-109/6921966-brushless-motor-question.html)
S!N!ST3R RC hObbys 01-17-2008 11:50 AM
Will the Ammo brushless that people are upgrading to
in the BJBL26 Take (x2) 3s 20c 11.1v 5400mah lipo's with
the 240Barricuda ESC??? THATS 22.2V will the wires and motor
work with that kind of volts, if not, what motor will????[>:]
BB Modss 01-17-2008 11:54 AM
RE: Brushless Motor question??
a 6s system would be in the 1300kv to 1500kv range, 6s is to hot for the ammo motor.try a 540-14xl
CadillacDTS2001 01-17-2008 12:28 PM
going 6s on the hydra 240 is no recommended, even thought it says you can do it, ill bet you dollars to dough nuts that it pooches it self
S!N!ST3R RC hObbys 01-17-2008 01:04 PM
Then what ESC will take 6s lipo 11.1v??????
BB Modss 01-17-2008 01:08 PM
why not find a nice 2400kv motor and run 3s2p for extra long run times?
wiggledude 01-17-2008 02:03 PM
What kind of running are you aiming for?
BB Modss 01-17-2008 06:41 PM
I see your from Cullman, im from scottsboro originally. Look on unitedhobbies for a HV esc, 100 amps and 12s ready for about $100, but remember the motor you have selected will not run 6s, you will likely ruin the esc trying to make it run that way. while your on there site, try and look for a 14xl.
S!N!ST3R RC hObbys 01-17-2008 10:53 PM
Will it be ok to use the Castle creations Hydra240 w/25volt max and 240 max amps??
what does cells no BEC mean, will this esc let me use 6s lipo???
BB Modss 01-17-2008 11:05 PM
castle esc's that say they have a max of 6s can not run 6s for long, use 5s max, BEC is battery eliminator circuit, over a certain voltage you have to cut or remove the middle red wire on the servo plug going to the receiver, then use a external 4 or 5 cell battery pack to power the servos and esc's controller. you dont need the 240 in sport boats, the 120 will be fine, but on 3s2p and a 7xl it would give you some headroom to run a bigger prop, motor life will be cut down a tad, but not to much.
